How do I create a project for mimxrt117 with Ethernet and LwIP stack working?
sandeep_c
RaRo
Hello @sandeep_c,
Could you please check the following information and try it out:
Also, we recommend you to use MCUXpresso IDE for NXP MCUs; there, after you download the SDK of the microcontroller, you could start using the examples of lwip and then modify them as you need.
Hope any of this helps you to start with your project.
Best regards, Raul.
RaRo
Hello @sandeep_c,
Best regards, Raul.
