Write a FlashLoader
3,372件の閲覧回数
Devyy
Hello everyone,
I'm a beginner in embedded system programmation and I want to create my own flash loader to download and write a programme using UART. I'm using a kinetis mkv58f1m0vlq24.
I dont want to use any libraries function like "flash_memory_write". I'm just trying to improve my skills.
My question is what are the steps to achieve to write in flash memory ?
I read datasheets and it seems to have a flash security but when i'm watching my registers, the security seems to not be active.
What I understood is that before every write in memory, i have to erase the memory area.
Thank you in advance for your answers,
Devyy
3,351件の閲覧回数
ErichStyger
Specialist I
Hi @Devyy ,
you might have a look at https://mcuoneclipse.com/2013/04/28/serial-bootloader-for-the-freedom-board-with-processor-expert/
Basically, you need
a) implement the UART/serial driver
b) define a data protocol and parser (e.g. reading S19 files)
c) program the flash memory. Have a look at the SDK for the flash drivers
d) do all the controlling around: reset handling, reset vector, vector table
good luck!
3,352件の閲覧回数
ErichStyger
Specialist I
Hi @Devyy ,
Basically, you need
good luck!
3,338件の閲覧回数
Devyy
Hi !
I have read what you sent. It will help me for sure.
Thank you so much !
