ls1043ardb uboot set eMMC hs200 mode boot failed
已解决
跳至解决方案
2,818 次查看
kevin_Tao
1. I set eMMC hs200 mode in uboot, boot kernel stop at Starting kernel ...
boot log:
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:2...
Found U-Boot script /boot/ls1043ardb_boot.scr
1053 bytes read in 16 ms (63.5 KiB/s)
## Executing script at 80000000
12409308 bytes read in 435 ms (27.2 MiB/s)
26755 bytes read in 22 ms (1.2 MiB/s)
## Booting kernel from Legacy Image at 81000000 ...
Image Name: ARM64 OpenWrt Linux-5.15.124
Image Type: AArch64 Linux Kernel Image (gzip compressed)
Data Size: 12409244 Bytes = 11.8 MiB
Load Address: 80000000
Entry Point: 80000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 90000000
Booting using the fdt blob at 0x90000000
Uncompressing Kernel Image
Using Device Tree in place at 0000000090000000, end 0000000090019882
Starting kernel ...           // stop at here
 2. What's more, eMMC high-speed mode start kernel OK
3. emmc set hs200 mode , uboot change as follow :
3.1  flexbuild_lsdk2108/components/firmware/uboot/configs/ls1043ardb_tfa_defconfig add CONFIG_MMC_HS200_SUPPORT=y
3.2  ls1043ardb uboot dts modify follows: [v2,2/5] arm64: dts: ls1046a: support SD UHS-I and eMMC HS200 on RDB - Patchwork (kernel.org)
3.3 mmc info message:
=> mmc info
Device: FSL_SDHC
Manufacturer ID: 13
OEM: 14e
Bus Speed: 166666666
Mode: HS200 (200MHz)
Rd Block Len: 512
MMC version 5.1
High Capacity: Yes
Capacity: 29.6 GiB
Bus Width: 4-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 29.6 GiB WRREL
Boot Capacity: 31.5 MiB ENH
RPMB Capacity: 4 MiB ENH
Boot area 0 is not write protected
Boot area 1 is not write protected
I want to operate eMMC in HS200 mode in uboot , So for that which configurations I have to change?
I only set eMMC mode high-speed to HS200 in uboot , Why  stop at Starting kernel ... ?
TKS!
Best Regards
1 解答
2,711 次查看
kevin_Tao
Thank you very much for your reply!I have solved the problem is the power.
在原帖中查看解决方案
3 回复数
2,736 次查看
June_Lu
Have the patches below checked?
[v3, 0/5] Add eSDHC UHS-I/HS200 mode support for ls1012a/ls1046a/ls208xa - Yangbo Lu (kernel.org)
In additon, these dts patches depends on esdhc driver patches which just had been merged
on mmc.git. Otherwise, the UHS-I SD card and eMMC HS200 card would fail to be initialized,
but other cards still could work fine.
https://patchwork.kernel.org/patch/9689875/
https://patchwork.kernel.org/patch/9689877/
https://patchwork.kernel.org/patch/9689879/
https://patchwork.kernel.org/patch/9689887/
https://patchwork.kernel.org/patch/9689885/
2,739 次查看
June_Lu
Would you check the kernel eMMC speed?
2,712 次查看
kevin_Tao
%3CLINGO-SUB%20id%3D%22lingo-sub-1848033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Els1043ardb%20uboot%E8%AE%BE%E7%BD%AEeMMC%20hs200%E6%A8%A1%E5%BC%8F%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1848033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3CSPAN%3E1.%E6%88%91%E5%9C%A8%20uboot%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%E4%BA%86%20eMMC%20hs200%20%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8%E5%81%9C%E6%AD%A2%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A0%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%88%86%E5%8C%BA%230%EF%BC%8C%E7%A1%AE%E5%AE%9A%3CBR%20%2F%3Emmc0%EF%BC%88%E7%AC%AC%200%20%E9%83%A8%E5%88%86%EF%BC%89%E6%98%AF%E5%BD%93%E5%89%8D%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E6%89%AB%E6%8F%8F%20mmc%200%3A2...%3CBR%20%2F%3E%E6%89%BE%E5%88%B0%20U-Boot%20%E8%84%9A%E6%9C%AC%20%2Fboot%2Fls1043ardb_boot.scr%3CBR%20%2F%3E16%20%E6%AF%AB%E7%A7%92%E5%86%85%E8%AF%BB%E5%8F%96%201053%20%E5%AD%97%E8%8A%82%EF%BC%8863.5%20KiB%2Fs%EF%BC%89%3CBR%20%2F%3E%20%23%23%20Executing%20script%20at%2080000000%3CBR%20%2F%3E12409308%20bytes%20read%20in%20435%20ms%20(27.2%20MiB%2Fs)%3CBR%20%2F%3E26755%20bytes%20read%20in%2022%20ms%20(1.2%20MiB%2Fs)%3CBR%20%2F%3E%23%23%E4%BB%8E%2081000000%20%E5%A4%84%E7%9A%84%E6%97%A7%E6%98%A0%E5%83%8F%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3CBR%20%2F%3E%E9%95%9C%E5%83%8F%E5%90%8D%E7%A7%B0%EF%BC%9AARM64%20OpenWrt%20Linux-5.15.124%3CBR%20%2F%3E%E9%95%9C%E5%83%8F%E7%B1%BB%E5%9E%8B%EF%BC%9AAArch64%20Linux%20%E5%86%85%E6%A0%B8%E9%95%9C%E5%83%8F%EF%BC%88gzip%20%E5%8E%8B%E7%BC%A9%EF%BC%89%3CBR%20%2F%3E%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%EF%BC%9A12409244%20%E5%AD%97%E8%8A%82%20%3D%2011.8%E5%AF%86%E5%B0%94%E5%B8%83%3CBR%20%2F%3E%E5%8A%A0%E8%BD%BD%E5%9C%B0%E5%9D%80%EF%BC%9A80000000%3CBR%20%2F%3E%E5%85%A5%E5%8F%A3%E7%82%B9%EF%BC%9A80000000%3CBR%20%2F%3E%E9%AA%8C%E8%AF%81%E6%A0%A1%E9%AA%8C%E5%92%8C...%E7%A1%AE%E5%AE%9A%3CBR%20%2F%3E%23%23%20%E6%89%81%E5%B9%B3%E8%AE%BE%E5%A4%87%E6%A0%91%20blob%20%E4%BD%8D%E4%BA%8E%2090000000%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E4%BD%8D%E4%BA%8E%200x90000000%20%E7%9A%84%20fdt%20blob%20%E8%BF%9B%E8%A1%8C%E5%BC%95%E5%AF%BC%3CBR%20%2F%3E%E8%A7%A3%E5%8E%8B%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E4%BD%8D%E4%BA%8E%200000000090000000%20%E5%A4%84%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%EF%BC%8C%E7%BB%93%E6%9D%9F%E4%BA%8E%200000000090019882%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FFONT%3E%20%2F%2F%E5%9C%A8%E6%AD%A4%E5%A4%84%E5%81%9C%E6%AD%A2%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E2.%20%E5%8F%A6%E5%A4%96%EF%BC%8C%3C%2FSPAN%3E%20%3CSPAN%3EeMMC%3C%2FSPAN%3E%3CSPAN%3E%E9%AB%98%E9%80%9F%E6%A8%A1%E5%BC%8F%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8OK%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E3.%20emmc%E8%AE%BE%E7%BD%AEhs200%E6%A8%A1%E5%BC%8F%EF%BC%8Cuboot%E6%9B%B4%E6%94%B9%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E3.1%20flexbuild_lsdk2108%2Fcomponents%2Ffirmware%2Fuboot%2Fconfigs%2Fls1043ardb_tfa_defconfig%20%E6%B7%BB%E5%8A%A0%20CONFIG_MMC_HS200_SUPPORT%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E3.2%20ls1043ardb%20uboot%20dts%20%E4%BF%AE%E6%94%B9%E5%A6%82%E4%B8%8B%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fpatchwork.kernel.org%2Fproject%2Flinux-arm-kernel%2Fpatch%2F1493894940-47452-3-git-send-email-yangbo.lu%40nxp.com%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%5Bv2%2C2%2F5%5D%20arm64%3A%20dts%3A%20ls1046a%3A%20%E5%9C%A8%20RDB%20%E4%B8%8A%E6%94%AF%E6%8C%81%20SD%20UHS-I%20%E5%92%8C%20eMMC%20HS200%20-%20Patchwork%20(kernel.org)%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E3.3%20mmc%E4%BF%A1%E6%81%AF%E6%B6%88%E6%81%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3D%26gt%3B%20mmc%20%E4%BF%A1%E6%81%AF%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%EF%BC%9AFSL_SDHC%3CBR%20%2F%3E%E5%88%B6%E9%80%A0%E5%95%86%20ID%EF%BC%9A13%3CBR%20%2F%3E%E5%8E%9F%E5%A7%8B%E8%AE%BE%E5%A4%87%E5%88%B6%E9%80%A0%E5%95%86%EF%BC%9A14e%3CBR%20%2F%3E%E5%90%8D%E7%A7%B0%EF%BC%9AG1M15%3CBR%20%2F%3E%E6%80%BB%E7%BA%BF%E9%80%9F%E5%BA%A6%EF%BC%9A166666666%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E6%A8%A1%E5%BC%8F%EF%BC%9AHS200%EF%BC%88200MHz%EF%BC%89%3C%2FFONT%3E%3CBR%20%2F%3E%E8%B7%AF%E5%9D%97%E9%95%BF%E5%BA%A6%EF%BC%9A512%3CBR%20%2F%3E%20MMC%20%E7%89%88%E6%9C%AC%205.1%3CBR%20%2F%3E%E9%AB%98%E5%AE%B9%E9%87%8F%EF%BC%9A%E6%98%AF%3CBR%20%2F%3E%E5%AE%B9%E9%87%8F%EF%BC%9A29.6%20GiB%3CBR%20%2F%3E%E6%80%BB%E7%BA%BF%E5%AE%BD%E5%BA%A6%EF%BC%9A4%E4%BD%8D%3CBR%20%2F%3E%E6%93%A6%E9%99%A4%E7%BB%84%E5%A4%A7%E5%B0%8F%EF%BC%9A512%20KiB%3CBR%20%2F%3E%20HC%20WP%20%E7%BE%A4%E7%BB%84%E8%A7%84%E6%A8%A1%EF%BC%9A8%20MiB%3CBR%20%2F%3E%E7%94%A8%E6%88%B7%E5%AE%B9%E9%87%8F%EF%BC%9A29.6%20GiB%20WRREL%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%E5%AE%B9%E9%87%8F%EF%BC%9A31.5%20MiB%20ENH%3CBR%20%2F%3E%20RPMB%E5%AE%B9%E9%87%8F%EF%BC%9A4%20MiB%20ENH%3CBR%20%2F%3E%E5%BC%95%E5%AF%BC%E5%8C%BA%E5%9F%9F%200%20%E6%B2%A1%E6%9C%89%E5%86%99%E4%BF%9D%E6%8A%A4%3CBR%20%2F%3E%E5%BC%95%E5%AF%BC%E5%8C%BA%201%20%E6%B2%A1%E6%9C%89%E5%86%99%E4%BF%9D%E6%8A%A4%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%88%91%E6%83%B3%E5%9C%A8%20uboot%20%E4%B8%AD%E4%BB%A5%20HS200%20%E6%A8%A1%E5%BC%8F%E6%93%8D%E4%BD%9C%20eMMC%EF%BC%8C%E9%82%A3%E4%B9%88%E6%88%91%E9%9C%80%E8%A6%81%E6%9B%B4%E6%94%B9%E5%93%AA%E4%BA%9B%E9%85%8D%E7%BD%AE%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E5%9C%A8%20uboot%20%E4%B8%AD%E5%8F%AA%E8%AE%BE%E7%BD%AE%E4%BA%86%20eMMC%20%E6%A8%A1%E5%BC%8F%E9%AB%98%E9%80%9F%E4%B8%BA%20HS200%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8%E6%97%B6%E5%B0%B1%E5%81%9C%E4%BA%86%E2%80%A6%E2%80%A6%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ETKS!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1859310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Als1043ardb%20uboot%20%E8%AE%BE%E7%BD%AE%20eMMC%20hs200%20%E6%A8%A1%E5%BC%8F%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1859310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%81%E6%88%91%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%E4%BA%86%E7%94%B5%E6%BA%90%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857430%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Als1043ardb%20uboot%20%E8%AE%BE%E7%BD%AE%20eMMC%20hs200%20%E6%A8%A1%E5%BC%8F%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857430%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%E4%B8%8B%E9%9D%A2%E7%9A%84%E8%A1%A5%E4%B8%81%E6%A3%80%E6%9F%A5%E8%BF%87%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Flore.kernel.org%2Fall%2F1494297429-12083-1-git-send-email-yangbo.lu%40nxp.com%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%5Bv3%2C%200%2F5%5D%20%E4%B8%BA%20ls1012a%2Fls1046a%2Fls208xa%20%E6%B7%BB%E5%8A%A0%20eSDHC%20UHS-I%2FHS200%20%E6%A8%A1%E5%BC%8F%E6%94%AF%E6%8C%81%20-%20Yangbo%20Lu%20(kernel.org)%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%209.75pt%3B%22%3E%3CSPAN%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E8%BF%99%E4%BA%9B%20dts%20%E8%A1%A5%E4%B8%81%E4%BE%9D%E8%B5%96%E4%BA%8E%E5%88%9A%E5%88%9A%E5%90%88%E5%B9%B6%E7%9A%84%20esdhc%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%A1%A5%E4%B8%81%3CBR%20%2F%3E%E5%9C%A8%20mmc.git%20%E4%B8%8A%E3%80%82%E5%90%A6%E5%88%99%EF%BC%8CUHS-I%20SD%20%E5%8D%A1%E5%92%8C%20eMMC%20HS200%20%E5%8D%A1%E5%B0%86%E6%97%A0%E6%B3%95%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%8C%3CBR%20%2F%3E%E4%BD%86%E5%85%B6%E4%BB%96%E5%8D%A1%E4%BB%8D%E7%84%B6%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CA%20href%3D%22https%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689875%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689875%2F%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CA%20href%3D%22https%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689877%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689877%2F%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CA%20href%3D%22https%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689879%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689879%2F%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CA%20href%3D%22https%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689887%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689887%2F%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CA%20href%3D%22https%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689885%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689885%2F%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1856585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Als1043ardb%20uboot%20%E8%AE%BE%E7%BD%AE%20eMMC%20hs200%20%E6%A8%A1%E5%BC%8F%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%E4%BD%A0%E4%BC%9A%E6%A3%80%E6%9F%A5%E5%86%85%E6%A0%B8%20eMMC%20%E9%80%9F%E5%BA%A6%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
