ls1043ardb uboot set eMMC hs200 mode boot failed
2,842件の閲覧回数
kevin_Tao
1. I set eMMC hs200 mode in uboot, boot kernel stop at Starting kernel ...
boot log:
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:2...
Found U-Boot script /boot/ls1043ardb_boot.scr
1053 bytes read in 16 ms (63.5 KiB/s)
## Executing script at 80000000
12409308 bytes read in 435 ms (27.2 MiB/s)
26755 bytes read in 22 ms (1.2 MiB/s)
## Booting kernel from Legacy Image at 81000000 ...
Image Name: ARM64 OpenWrt Linux-5.15.124
Image Type: AArch64 Linux Kernel Image (gzip compressed)
Data Size: 12409244 Bytes = 11.8 MiB
Load Address: 80000000
Entry Point: 80000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 90000000
Booting using the fdt blob at 0x90000000
Uncompressing Kernel Image
Using Device Tree in place at 0000000090000000, end 0000000090019882
Starting kernel ...           // stop at here
 2. What's more, eMMC high-speed mode start kernel OK
3. emmc set hs200 mode , uboot change as follow :
3.1  flexbuild_lsdk2108/components/firmware/uboot/configs/ls1043ardb_tfa_defconfig add CONFIG_MMC_HS200_SUPPORT=y
3.2  ls1043ardb uboot dts modify follows: [v2,2/5] arm64: dts: ls1046a: support SD UHS-I and eMMC HS200 on RDB - Patchwork (kernel.org)
3.3 mmc info message:
=> mmc info
Device: FSL_SDHC
Manufacturer ID: 13
OEM: 14e
Bus Speed: 166666666
Mode: HS200 (200MHz)
Rd Block Len: 512
MMC version 5.1
High Capacity: Yes
Capacity: 29.6 GiB
Bus Width: 4-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 29.6 GiB WRREL
Boot Capacity: 31.5 MiB ENH
RPMB Capacity: 4 MiB ENH
Boot area 0 is not write protected
Boot area 1 is not write protected
I want to operate eMMC in HS200 mode in uboot , So for that which configurations I have to change?
I only set eMMC mode high-speed to HS200 in uboot , Why  stop at Starting kernel ... ?
TKS!
Best Regards
2,735件の閲覧回数
kevin_Tao
Thank you very much for your reply!I have solved the problem is the power.
3 返答(返信)
2,760件の閲覧回数
June_Lu
Have the patches below checked?
[v3, 0/5] Add eSDHC UHS-I/HS200 mode support for ls1012a/ls1046a/ls208xa - Yangbo Lu (kernel.org)
In additon, these dts patches depends on esdhc driver patches which just had been merged
on mmc.git. Otherwise, the UHS-I SD card and eMMC HS200 card would fail to be initialized,
but other cards still could work fine.
https://patchwork.kernel.org/patch/9689875/
https://patchwork.kernel.org/patch/9689877/
https://patchwork.kernel.org/patch/9689879/
https://patchwork.kernel.org/patch/9689887/
https://patchwork.kernel.org/patch/9689885/
2,763件の閲覧回数
June_Lu
Would you check the kernel eMMC speed?
2,736件の閲覧回数
kevin_Tao
%3CLINGO-SUB%20id%3D%22lingo-sub-1848033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Els1043ardb%20uboot%20set%20eMMC%20hs200%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1848033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3CSPAN%3E1.uboot%E3%81%A7eMMC%20hs200%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%82%B0%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%BE%E3%81%99%3A0%3CBR%20%2F%3E%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%230%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%A6%E3%80%81OK%3CBR%20%2F%3Emmc0(%E3%83%91%E3%83%BC%E3%83%880)%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3CBR%20%2F%3E%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%20mmc%200%3A2...%3CBR%20%2F%3EU-Boot%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%20%2Fboot%2Fls1043ardb_boot.scr%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1053%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%2016%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%20(63.5%20KiB%2Fs)%3CBR%20%2F%3E%23%23%20Executing%20script%20at%2080000000%3CBR%20%2F%3E12409308%20bytes%20read%20in%20435%20ms%20(27.2%20MiB%2Fs)%3CBR%20%2F%3E26755%20bytes%20read%20in%2022%20ms%20(1.2%20MiB%2Fs)%3CBR%20%2F%3E%23%23%20%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8B%E3%82%89%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%2081000000%20%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20...%3CBR%20%2F%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E5%90%8D%3A%20ARM64%20OpenWrt%20Linux-5.15.124%3CBR%20%2F%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%BF%E3%82%A4%E3%83%97%3A%20AArch64%20Linux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8(gzip%E5%9C%A7%E7%B8%AE)%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%B5%E3%82%A4%E3%82%BA%3A%2012409244%20%E3%83%90%E3%82%A4%E3%83%88%20%3D%2011.8MiB%E3%81%AE%3CBR%20%2F%3E%E3%83%AD%E3%83%BC%E3%83%89%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A80000000%3CBR%20%2F%3E%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3A80000000%3CBR%20%2F%3E%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%23%23%2090000000%20%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E3%83%96%E3%83%AD%E3%83%96%3CBR%20%2F%3E0x90000000%20%E3%81%A7%20fdt%20blob%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%96%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E8%A7%A3%E5%87%8D%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%82%920000000090000000%E3%80%81%E3%82%A8%E3%83%B3%E3%83%890000000090019882%E3%81%A7%E6%89%80%E5%AE%9A%E3%81%AE%E4%BD%8D%E7%BD%AE%E3%81%AB%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%3C%2FFONT%3E%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%E3%81%93%E3%81%93%E3%81%A7%E5%81%9C%E6%AD%A2%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%202.%20%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%3C%2FSPAN%3E%3CSPAN%3EeMMC%3C%2FSPAN%3E%3CSPAN%3E%E9%AB%98%E9%80%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95OK%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E3.%20eMMC%E3%81%AFHS200%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81uboot%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E3.1%20flexbuild_lsdk2108%2Fcomponents%2Ffirmware%2Fuboot%2Fconfigs%2Fls1043ardb_tfa_defconfig%20CONFIG_MMC_HS200_SUPPORT%3Dy%20%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E3.2%20ls1043ardb%20uboot%20DTS%20modify%20follows%3A%20%3CA%20href%3D%22https%3A%2F%2Fpatchwork.kernel.org%2Fproject%2Flinux-arm-kernel%2Fpatch%2F1493894940-47452-3-git-send-email-yangbo.lu%40nxp.com%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%5Bv2%2C2%2F5%5D%20arm64%3A%20dts%3A%20ls1046a%3A%20RDB%20%E3%81%A7%20SD%20UHS-I%20%E3%81%A8%20eMMC%20HS200%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20-%20%E3%83%91%E3%83%83%E3%83%81%E3%83%AF%E3%83%BC%E3%82%AF%20(kernel.org)%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E3.3%20MMC%E6%83%85%E5%A0%B1%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3D%26gt%3B%20mmc%20%E6%83%85%E5%A0%B1%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3AFSL_SDHC%3CBR%20%2F%3E%E3%83%A1%E3%83%BC%E3%82%AB%E3%83%BCID%3A%2013%3CBR%20%2F%3E%E3%81%AEOEM%20%3A14e%3CBR%20%2F%3E%E5%90%8D%E5%89%8D%3A%20G1M15%3CBR%20%2F%3E%E3%83%90%E3%82%B9%E3%81%AE%E9%80%9F%E5%BA%A6%3A166666666%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E3%83%A2%E3%83%BC%E3%83%89%3AHS200(200MHz)%3C%2FFONT%3E%3CBR%20%2F%3ERd%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%83%B3%3A512%3CBR%20%2F%3EMMC%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%205.1%3CBR%20%2F%3E%E5%A4%A7%E5%AE%B9%E9%87%8F%3A%E3%81%AF%E3%81%84%3CBR%20%2F%3E%E5%AE%B9%E9%87%8F%3A%2029.6%20GiB%3CBR%20%2F%3E%E3%83%90%E3%82%B9%E5%B9%85%3A4%E3%83%93%E3%83%83%E3%83%88%3CBR%20%2F%3E%E6%B6%88%E5%8E%BB%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%82%B5%E3%82%A4%E3%82%BA%3A%20512%20KiB%3CBR%20%2F%3EHC%20WP%20%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%83%BB%E3%82%B5%E3%82%A4%E3%82%BA%3A%208%20MiB%3CBR%20%2F%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E5%AE%B9%E9%87%8F%3A%2029.6%20GiB%20WRREL%3CBR%20%2F%3E%E3%83%96%E3%83%BC%E3%83%88%E5%AE%B9%E9%87%8F%3A%2031.5%20MiB%20ENH%3CBR%20%2F%3ERPMB%E5%AE%B9%E9%87%8F%3A4MiB%20ENH%3CBR%20%2F%3E%E3%83%96%E3%83%BC%E3%83%88%E9%A0%98%E5%9F%9F%200%20%E3%81%AF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%96%E3%83%BC%E3%83%88%E9%A0%98%E5%9F%9F%201%20%E3%81%AF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Euboot%E3%81%A7HS200%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7eMMC%E3%82%92%E6%93%8D%E4%BD%9C%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%81%A9%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Euboot%E3%81%A7eMMC%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E9%AB%98%E9%80%9F%E3%82%92HS200%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%81%A0%E3%81%91%E3%81%AA%E3%81%AE%E3%81%AB%E3%80%81%E3%81%AA%E3%81%9C%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%A7%E6%AD%A2%E3%81%BE%E3%82%8B%E3%81%AE%E3%81%8B...%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ETKS!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1859310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Als1043ardb%20uboot%20set%20eMMC%20hs200%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1859310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%9F%E3%81%AE%E3%81%AF%E5%8A%9B%E3%81%A7%E3%81%99%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857430%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Als1043ardb%20uboot%20set%20eMMC%20hs200%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857430%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Flore.kernel.org%2Fall%2F1494297429-12083-1-git-send-email-yangbo.lu%40nxp.com%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%5BV3%E3%80%810%2F5%5Dls1012a%2Fls1046a%2Fls208xa%20-%20Yangbo%20Lu%20(kernel.org)%20%E3%81%AE%20eSDHC%20UHS-I%2FHS200%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%209.75pt%3B%22%3E%3CSPAN%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%20dts%20%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81%E3%83%9E%E3%83%BC%E3%82%B8%E3%81%95%E3%82%8C%E3%81%9F%E3%81%B0%E3%81%8B%E3%82%8A%E3%81%AE%20esdhc%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Emmc.git%20%E3%81%A7%E3%80%82%E3%81%9D%E3%81%86%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81UHS-I%20SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%A8eMMC%20HS200%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BB%96%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AF%E3%81%BE%E3%81%A0%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689875%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689875%2F%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689877%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689877%2F%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689879%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689879%2F%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689887%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689887%2F%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689885%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fpatchwork.kernel.org%2Fpatch%2F9689885%2F%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1856585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Als1043ardb%20uboot%20set%20eMMC%20hs200%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AEeMMC%E3%81%AE%E9%80%9F%E5%BA%A6%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E
