ls1026a linux
ls1026a linux
2,741 次查看
renaud
we have a prototype using a LS1026A. We go tout boot loader booting and no are trying to boot Linux. The kernel we are using is running on the LS1046ardb eval board.
Linux dies upon returning from  the init_el1 function.
Any clue why this would happen?
Cheers,
Renaud
标记 (3)
4 回复数
2,669 次查看
renaud
. I used the PPA firmware from 2018 and Linux boots now.
2,730 次查看
renaud
Returning from the function is when the "eret" instructions is run.
2,732 次查看
renaud
Is that related to the use of the PPA firmware?
2,701 次查看
Oswalag
Hello, for newer versions of LSDK the TFA firmware (LSDK 18.12 onward) replaces PPA firmware (LSDK 18.09) as trusted firmware in U-Boot boot flow, please check what version you are using.
