Need help navigating the waters on a) creating a custom machine b) creating a custom image.
devnull0
I've been building images w/ yocto for a custom board that's similar to a LS1046ARDB (basically a simplified version of it). The image I've been building/testing up to now is bitbake fsl-image-kernelitb which uses the image fsl-image-mfgtool which extends core-image-minimal.
Our custom board doesn't have everything that the LS1046ARDB has so I would like to setup a more pristine/polished  machine config and image. I'm very new to Yocto though and need help navigating the waters of how does one go about this. So my two questions are ...
  • How does one create a custom machine configuration (where in my case I could base it off of the LS1046ARDB)?
  • How does one create a custom-image that extends say core-image-base/minimal but pulls in all the necessary qoriq stuff (e.g. like fsl-image-mfgtool does)?
Chavira
Hi @devnull0!
Sorry, we don't have a document explaining that, but you can consult the Yocto Documentation for that.
https://docs.yoctoproject.org/dev-manual/new-machine.html
Best Regards!
Chavira
