The CodeWarrior Tap simulator is unable to recognize
Zhoute
I encountered the following problems when debugging the lx2080 target board.Even if I use the network port or USB for debugging, the simulator still shows that it cannot connect.And synchronized CodeWarrior Connection Server has encountered the following issues.
Have you ever encountered such a question? I have tried many of the methods provided in the official documents as well as those available on the internet, but none of them worked.
LX2160A-RDB
June_Lu
Could you ping the CWTAP?
What's your CWTAP version?
What's your CodeWarrior IDE version?
Zhoute
@June_Lu Thank you very much for your reply.
1.I can ping the CWTAP,(Windows-cmd.exe use ping FSL082481 command,it's OK.)
2.We have two CWTAP emulator,one is <REV H 23201440>,the other one is <REV G 20461200>
3. My CodeWarrior IDE version is:
The latest upgrade package has also been imported.
June_Lu
Please update it to the CodeWarrior IDE version 11.5.12.
On the NXP website.
My NXP Account->Software->Software Licensing and Support->View accounts->Product List->CodeWarrior for QorIQ LS Series ARMv8 ISA->
Please download update package
com.freescale.armv8.11.5.12.GA.Win.updatesite.221209.zip
Please open CodeWarrior from C:\Freescale\CW4NET_v2020.06\CW_ARMv8\fsl_eclipse.bat, and install the update package from Help->Install New Software->Add->Archive.
And then try the ccs command.
You could reply in Chinese.
Zhoute
@June_Lu 感谢,软件已经升级到指定版本了
启动CCS后,按照您提供的输入指令,出现如下情况:
请问该如何定位问题呢?
June_Lu
用USB直接连接到PC上,用下面的命令,看是否工作正常
(bin) 8 % config cc cwtap
(bin) 9 % show cc
Zhoute
@June_Lu
用USB直接连接到PC上,用下面的命令,结果如下图所示:
June_Lu
(bin) 7 % delete all
(bin) 9 % show cc
每次都要delete all
连上G version试一下,USB连接,H version,firmware变更了
Zhoute
@June_Lu
这是连上G version后的效果。
还有一些硬件问题麻烦您答疑一下,十分感谢。
1.连接仿真器时RCW_SRC[3:0],还有TBSCAN_EN_B怎么配置?,也就是CFG_DRV置高开始配置的时候,配置完(复位完成后)这几个管脚应该怎么处理?
十分感谢
June_Lu
我断开了CWTAP的网络连接,发现了与您类似的错误,请检查您CWTAP的连接。
(bin) 8 % config cc cwtap:10.193.20.174
(bin) 9 % show cc
0: Network timeout
There are no command converters configured
June_Lu
如果这个问题一直存在,建议你换一台PC机,重新安装CW试一下,并且确认使用CWTAP之前,设备管理器都可以识别CWTAP串口并能输入CWTAP的信息。
因为我手上的GH version都无法复现这个问题。
LX2160ARDBGSG中,有对RCW_SRC[3:0]和TBSCAN_EN_B的配置描述。
CFG_DRV不知道您指什么。
June_Lu
In the ccs, please run:
(bin) 8 % config cc cwtap:10.193.21.52//(it's your CWTAP ethernet IP)
(bin) 9 % show cc
(bin) 10 % ccs::config_chain {lx2160a dap}
(bin) 11 % display ::ccs::get_config_chain
(bin) 12 % ccs::reset_to_debug
Zhoute
@June_Lu Could you please send me the pin definitions (in the Jtag section) of the CodeWarrior Tap simulator? We are currently connecting the target board lx2080 through specific signals (TDI/TDO/TCK/TMS/RESET/VDD/GND). The CodeWarrior Tap simulator has been constantly indicating the above error.
When I click the connection button, the following problems will occur
And the CodeWarrior Tap emulator's light (RUN/PAUSE) remained orange all the time, which was not the red color as stated in the official documentation.
I'm looking forward to your reply,Thanks.
Zhoute
Hi,June_Lu,Thank you!I use your advice but not work,Below this picture is the problem,I don't know why.I searched for the relevant errors(CC not present), but failed to solve the problem.
@June_Lu
%3CLINGO-SUB%20id%3D%22lingo-sub-2138806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThe%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20encountered%20the%20following%20problems%20when%20debugging%20the%20lx2080%20target%20board.Even%20if%20I%20use%20the%20network%20port%20or%20USB%20for%20debugging%2C%20the%20simulator%20still%20shows%20that%20it%20cannot%20connect.And%20synchronized%20CodeWarrior%20Connection%20Server%20has%20encountered%20the%20following%20issues.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_0-1753234432318.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_0-1753234432318.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348923iEDF6ADD49E7154D6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_0-1753234432318.png%22%20alt%3D%22Zhoute_0-1753234432318.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_1-1753234581325.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_1-1753234581325.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348925iD62BE43455FD892E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_1-1753234581325.png%22%20alt%3D%22Zhoute_1-1753234581325.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_2-1753235074494.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_2-1753235074494.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348926iEA70D4DF75929C75%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_2-1753235074494.png%22%20alt%3D%22Zhoute_2-1753235074494.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EHave%20you%20ever%20encountered%20such%20a%20question%3F%26nbsp%3BI%20have%20tried%20many%20of%20the%20methods%20provided%20in%20the%20official%20documents%20as%20well%20as%20those%20available%20on%20the%20internet%2C%20but%20none%20of%20them%20worked.%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FLX2160A-RDB%2Fpd-p%2FLX2160A-RDB%22%20class%3D%22lia-product-mention%22%20data-product%3D%223413-1%22%20target%3D%22_blank%22%3ELX2160A-RDB%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2143209%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2143209%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3EI%20disconnected%3C%2FSPAN%3E%3CSPAN%3E%20CWTAP%3C%2FSPAN%3E%3CSPAN%3E%20network%20connection%20and%20found%20an%20error%20similar%20to%20yours%2C%20please%20check%20your%3C%2FSPAN%3E%3CSPAN%3E%20CWTAP%3C%2FSPAN%3E%3CSPAN%3E%20connection.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E(bin)%207%20%25%20delete%20all%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E(bin)%208%20%25%20config%20cc%20cwtap%3A10.193.20.174%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E(bin)%209%20%25%20show%20cc%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E0%3A%20Network%20timeout%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3EThere%20are%20no%20command%20converters%20configured%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2141630%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2141630%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3EIf%20this%20problem%20persists%2C%20it%20is%20recommended%20that%20you%20get%20a%20different%3C%2FSPAN%3E%3CSPAN%3E%20PC%3C%2FSPAN%3E%3CSPAN%3E%20machine%20and%20reinstall%20the%3C%2FSPAN%3E%3CSPAN%3E%20CW%3C%2FSPAN%3E%3CSPAN%3E%20Try%20it%20and%20make%20sure%20to%20use%3C%2FSPAN%3E%3CSPAN%3E%20CWTAP%3C%2FSPAN%3E%3CSPAN%3E%20before%20using%20CWTAP%2C%20the%20device%20manager%20recognizes%3C%2FSPAN%3E%3CSPAN%3E%20CWTAP%3C%2FSPAN%3E%3CSPAN%3E%20serial%20port%20and%20can%20enter%3C%2FSPAN%3E%3CSPAN%3E%20CWTAP%3C%2FSPAN%3E%3CSPAN%3E%20information.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3EBecause%20I%20have%20in%20my%20hands%3C%2FSPAN%3E%3CSPAN%3E%20G%3C%2FSPAN%3E%3CSPAN%3E%20and%3C%2FSPAN%3E%3CSPAN%3E%20H%20%3C%2FSPAN%3E%3CSPAN%3E%20versions%3C%2FSPAN%3E%3CSPAN%3E%20are%20unable%20to%20reproduce%20the%20problem.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3ELX2160ARDBGSG%3C%2FSPAN%3E%3CSPAN%3E%20There%20are%20configuration%20descriptions%20for%20RCW_SRC%5B3%3A0%5D%20and%20TBSCAN_EN_B%20in%20the%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3ECFG_DRV%3C%2FSPAN%3E%3CSPAN%3E%20Not%20sure%20what%20you%20are%20referring%20to.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140201%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140201%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F204495%22%20target%3D%22_blank%22%3E%40June_Lu%3C%2FA%3E%20%3C%2FP%3E%3CP%3EThis%20is%20%3CSPAN%3Ewhat%20it%20looks%20like%20when%20connected%20to%20G%20version.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_0-1753363512039.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_0-1753363512039.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349343i208F6544544CE1DF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_0-1753363512039.png%22%20alt%3D%22Zhoute_0-1753363512039.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThere%20are%20also%20some%20hardware%20questions%20that%20I%20would%20appreciate%20you%20answering%2C%20thank%20you%20very%20much.%3C%2FP%3E%3CP%3E1.%20How%20to%20configure%20RCW_SRC%5B3%3A0%5D%20and%20TBSCAN_EN_B%20when%20connecting%20to%20the%20emulator%3F%20That%20is%2C%20when%20CFG_DRV%20is%20set%20high%20to%20start%20the%20configuration%2C%20what%20should%20be%20done%20with%20these%20pins%20after%20the%20configuration%20(after%20the%20reset%20is%20done)%3F%3C%2FP%3E%3CP%3Eextremely%20grateful%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E(bin)%207%20%25%20delete%20all%3CBR%20%2F%3E(bin)%208%20%25%20config%20cc%20cwtap%3CBR%20%2F%3E(bin)%209%20%25%20show%20cc%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AF%8F%E6%AC%A1%E9%83%BD%E8%A6%81delete%20all%3CBR%20%2F%3E%E8%BF%9E%E4%B8%8AG%20version%E8%AF%95%E4%B8%80%E4%B8%8B%EF%BC%8CUSB%E8%BF%9E%E6%8E%A5%EF%BC%8CH%20version%EF%BC%8Cfirmware%E5%8F%98%E6%9B%B4%E4%BA%86%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140175%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140175%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F204495%22%20target%3D%22_blank%22%3E%40June_Lu%3C%2FA%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EConnect%20directly%20to%20the%20PC%20with%20USB%20and%20use%20the%20following%20command%2C%20the%20result%20is%20shown%20below%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_0-1753361540331.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_0-1753361540331.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349336i3758E88B11FCE137%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_0-1753361540331.png%22%20alt%3D%22Zhoute_0-1753361540331.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140173%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140173%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EConnect%20directly%20to%20the%20PC%20with%20USB%20and%20use%20the%20following%20commands%20to%20see%20if%20it%20works%20properly%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E(bin)%208%20%25%20config%20cc%20cwtap%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E(bin)%209%20%25%20show%20cc%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140095%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140095%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F204495%22%20target%3D%22_blank%22%3E%40June_Lu%3C%2FA%3E%20Thanks%2C%20the%20software%20has%20been%20upgraded%20to%20the%20specified%20version!%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_0-1753353660039.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_0-1753353660039.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349310iFF5DDD9B2C0CC959%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_0-1753353660039.png%22%20alt%3D%22Zhoute_0-1753353660039.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EAfter%20starting%20CCS%2C%20the%20following%20occurs%20as%20per%20the%20input%20instructions%20you%20provided%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_1-1753353805264.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_1-1753353805264.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349311iF54A464FB6CD9E12%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_1-1753353805264.png%22%20alt%3D%22Zhoute_1-1753353805264.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EMay%20I%20ask%20how%20to%20locate%20the%20problem%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%3EPlease%20update%20it%20to%20the%20CodeWarrior%20IDE%20version%2011.5.12.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%3EOn%20the%20NXP%20website.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%3EMy%20NXP%20Account-%26gt%3BSoftware-%26gt%3BSoftware%20Licensing%20and%20Support-%26gt%3BView%20accounts-%26gt%3BProduct%20List-%26gt%3BCodeWarrior%20for%20QorIQ%20LS%20Series%20ARMv8%20ISA-%26gt%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%3EPlease%20download%20update%20package%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%3Ecom.freescale.armv8.11.5.12.GA.Win.updatesite.221209.zip%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%3EPlease%20open%20CodeWarrior%20from%20C%3A%5CFreescale%5CCW4NET_v2020.06%5CCW_ARMv8%5Cfsl_eclipse.bat%2C%20and%20install%20the%20update%20package%20from%20Help-%26gt%3BInstall%20New%20Software-%26gt%3BAdd-%26gt%3BArchive.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%20lang%3D%22en-US%22%3EAnd%20then%20try%20the%20ccs%20command.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%20lang%3D%22en-US%22%3EYou%20could%20reply%20in%20Chinese.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F204495%22%20target%3D%22_blank%22%3E%40June_Lu%3C%2FA%3E%26nbsp%3BThank%20you%20very%20much%20for%20your%20reply.%3C%2FP%3E%3CP%3E1.I%20can%20ping%20the%20CWTAP%2C(Windows-cmd.exe%20use%20ping%20FSL082481%20command%2Cit's%20OK.)%3C%2FP%3E%3CP%3E2.We%20have%20two%20CWTAP%26nbsp%3Bemulator%2Cone%20is%20%3CREV%20h%3D%22%22%2023201440%3D%22%22%3E%2Cthe%20other%20one%20is%20%3CREV%20g%3D%22%22%2020461200%3D%22%22%3E%3C%2FREV%3E%3C%2FREV%3E%3C%2FP%3E%3CP%3E3.%3CSPAN%3E%26nbsp%3BMy%20CodeWarrior%20IDE%20version%20is%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_0-1753338785256.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_0-1753338785256.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349266i5ED53C6105445609%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_0-1753338785256.png%22%20alt%3D%22Zhoute_0-1753338785256.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThe%20latest%20upgrade%20package%20has%20also%20been%20imported.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3ECould%20you%20ping%20the%20CWTAP%3F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EWhat's%20your%20CWTAP%20version%3F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EWhat's%20your%20CodeWarrior%20IDE%20version%3F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139285%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139285%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F204495%22%20target%3D%22_blank%22%3E%40June_Lu%3C%2FA%3E%26nbsp%3BCould%20you%20please%20send%20me%20the%20pin%20definitions%20(in%20the%20Jtag%20section)%20of%20the%20CodeWarrior%20Tap%20simulator%3F%20We%20are%20currently%20connecting%20the%20target%20board%20lx2080%20through%20specific%20signals%20(TDI%2FTDO%2FTCK%2FTMS%2FRESET%2FVDD%2FGND).%20The%20CodeWarrior%20Tap%20simulator%20has%20been%20constantly%20indicating%20the%20above%20error.%3C%2FP%3E%3CP%3EWhen%20I%20click%20the%20connection%20button%2C%20the%20following%20problems%20will%20occur%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_0-1753264228307.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_0-1753264228307.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349088i1801B502CB4E4D1A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_0-1753264228307.png%22%20alt%3D%22Zhoute_0-1753264228307.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EAnd%20the%20CodeWarrior%20Tap%20emulator's%20light%20(RUN%2FPAUSE)%20remained%20orange%20all%20the%20time%2C%20which%20was%20not%20the%20red%20color%20as%20stated%20in%20the%20official%20documentation.%3C%2FP%3E%3CP%3EI'm%20looking%20forward%20to%20your%20reply%2CThanks.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3EThe%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2CJune_Lu%2CThank%20you!I%20use%20your%20advice%20but%20not%20work%2CBelow%20this%20picture%20is%20the%20problem%2CI%20don't%20know%20why.I%20searched%20for%20the%20relevant%20errors(CC%20not%20present)%2C%20but%20failed%20to%20solve%20the%20problem.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_0-1753251599243.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_0-1753251599243.png%22%20style%3D%22width%3A%20369px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348995i38CE290B2828B10E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_0-1753251599243.png%22%20alt%3D%22Zhoute_0-1753251599243.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F204495%22%20target%3D%22_blank%22%3E%40June_Lu%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EIn%20the%20ccs%2C%20please%20run%3A%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E(bin)%207%20%25%20delete%20all%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E(bin)%208%20%25%20config%20cc%20cwtap%3A10.193.21.52%2F%2F(it's%20your%20CWTAP%20ethernet%20IP)%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E(bin)%209%20%25%20show%20cc%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E(bin)%2010%20%25%20ccs%3A%3Aconfig_chain%20%7Blx2160a%20dap%7D%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E(bin)%2011%20%25%20display%20%3A%3Accs%3A%3Aget_config_chain%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E(bin)%2012%20%25%20ccs%3A%3Areset_to_debug%3C%2FP%3E%3C%2FLINGO-BODY%3E
