The CodeWarrior Tap simulator is unable to recognize
5,203 次查看
Zhoute
I encountered the following problems when debugging the lx2080 target board.Even if I use the network port or USB for debugging, the simulator still shows that it cannot connect.And synchronized CodeWarrior Connection Server has encountered the following issues.
Have you ever encountered such a question? I have tried many of the methods provided in the official documents as well as those available on the internet, but none of them worked.
LX2160A-RDB
13 回复数
5,159 次查看
June_Lu
Could you ping the CWTAP?
What's your CWTAP version?
What's your CodeWarrior IDE version?
5,153 次查看
Zhoute
@June_Lu Thank you very much for your reply.
1.I can ping the CWTAP,(Windows-cmd.exe use ping FSL082481 command,it's OK.)
2.We have two CWTAP emulator,one is <REV H 23201440>,the other one is <REV G 20461200>
3. My CodeWarrior IDE version is:
The latest upgrade package has also been imported.
5,148 次查看
June_Lu
Please update it to the CodeWarrior IDE version 11.5.12.
On the NXP website.
My NXP Account->Software->Software Licensing and Support->View accounts->Product List->CodeWarrior for QorIQ LS Series ARMv8 ISA->
Please download update package
com.freescale.armv8.11.5.12.GA.Win.updatesite.221209.zip
Please open CodeWarrior from C:\Freescale\CW4NET_v2020.06\CW_ARMv8\fsl_eclipse.bat, and install the update package from Help->Install New Software->Add->Archive.
And then try the ccs command.
You could reply in Chinese.
5,143 次查看
Zhoute
@June_Lu 感谢,软件已经升级到指定版本了
启动CCS后,按照您提供的输入指令,出现如下情况:
请问该如何定位问题呢?
5,137 次查看
June_Lu
用USB直接连接到PC上,用下面的命令,看是否工作正常
(bin) 8 % config cc cwtap
(bin) 9 % show cc
5,135 次查看
Zhoute
@June_Lu
用USB直接连接到PC上,用下面的命令,结果如下图所示:
5,130 次查看
June_Lu
(bin) 7 % delete all
(bin) 9 % show cc
每次都要delete all
连上G version试一下,USB连接,H version,firmware变更了
5,125 次查看
Zhoute
@June_Lu
这是连上G version后的效果。
还有一些硬件问题麻烦您答疑一下,十分感谢。
1.连接仿真器时RCW_SRC[3:0],还有TBSCAN_EN_B怎么配置?,也就是CFG_DRV置高开始配置的时候,配置完(复位完成后)这几个管脚应该怎么处理?
十分感谢
4,782 次查看
June_Lu
我断开了CWTAP的网络连接,发现了与您类似的错误,请检查您CWTAP的连接。
(bin) 8 % config cc cwtap:10.193.20.174
(bin) 9 % show cc
0: Network timeout
There are no command converters configured
4,907 次查看
June_Lu
如果这个问题一直存在,建议你换一台PC机,重新安装CW试一下,并且确认使用CWTAP之前,设备管理器都可以识别CWTAP串口并能输入CWTAP的信息。
因为我手上的G和H version都无法复现这个问题。
LX2160ARDBGSG中,有对RCW_SRC[3:0]和TBSCAN_EN_B的配置描述。
CFG_DRV不知道您指什么。
5,194 次查看
June_Lu
In the ccs, please run:
(bin) 8 % config cc cwtap:10.193.21.52//(it's your CWTAP ethernet IP)
(bin) 9 % show cc
(bin) 10 % ccs::config_chain {lx2160a dap}
(bin) 11 % display ::ccs::get_config_chain
(bin) 12 % ccs::reset_to_debug
5,181 次查看
Zhoute
@June_Lu Could you please send me the pin definitions (in the Jtag section) of the CodeWarrior Tap simulator? We are currently connecting the target board lx2080 through specific signals (TDI/TDO/TCK/TMS/RESET/VDD/GND). The CodeWarrior Tap simulator has been constantly indicating the above error.
When I click the connection button, the following problems will occur
And the CodeWarrior Tap emulator's light (RUN/PAUSE) remained orange all the time, which was not the red color as stated in the official documentation.
I'm looking forward to your reply,Thanks.
5,190 次查看
Zhoute
Hi,June_Lu,Thank you!I use your advice but not work,Below this picture is the problem,I don't know why.I searched for the relevant errors(CC not present), but failed to solve the problem.
@June_Lu
%3CLINGO-SUB%20id%3D%22lingo-sub-2138806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECodeWarrior%20Tap%20%E6%A8%A1%E6%8B%9F%E5%99%A8%E6%97%A0%E6%B3%95%E8%AF%86%E5%88%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%9C%A8%E8%B0%83%E8%AF%95%20lx2080%20%E7%9B%AE%E6%A0%87%E6%9D%BF%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%E3%80%82%E5%8D%B3%E4%BD%BF%E6%88%91%E4%BD%BF%E7%94%A8%E7%BD%91%E7%BB%9C%E7%AB%AF%E5%8F%A3%E6%88%96%20USB%20%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%EF%BC%8C%E6%A8%A1%E6%8B%9F%E5%99%A8%E4%BB%8D%E7%84%B6%E6%98%BE%E7%A4%BA%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E3%80%82%E5%90%8C%E6%AD%A5%E7%9A%84%20CodeWarrior%20%E8%BF%9E%E6%8E%A5%E6%9C%8D%E5%8A%A1%E5%99%A8%E9%81%87%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_0-1753234432318.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_0-1753234432318.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348923iEDF6ADD49E7154D6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_0-1753234432318.png%22%20alt%3D%22Zhoute_0-1753234432318.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_1-1753234581325.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_1-1753234581325.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348925iD62BE43455FD892E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_1-1753234581325.png%22%20alt%3D%22Zhoute_1-1753234581325.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_2-1753235074494.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_2-1753235074494.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348926iEA70D4DF75929C75%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_2-1753235074494.png%22%20alt%3D%22Zhoute_2-1753235074494.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E9%81%87%E5%88%B0%E8%BF%87%E8%BF%99%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%20%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E8%AE%B8%E5%A4%9A%E5%AE%98%E6%96%B9%E6%96%87%E4%BB%B6%E5%92%8C%E4%BA%92%E8%81%94%E7%BD%91%E4%B8%8A%E6%8F%90%E4%BE%9B%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%8C%E4%BD%86%E9%83%BD%E6%B2%A1%E6%9C%89%E5%A5%8F%E6%95%88%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FLX2160A-RDB%2Fpd-p%2FLX2160A-RDB%22%20class%3D%22lia-product-mention%22%20data-product%3D%223413-1%22%20target%3D%22_blank%22%3ELX2160A-RDB%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2143209%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2143209%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3E%E6%88%91%E6%96%AD%E5%BC%80%E4%BA%86%3C%2FSPAN%3E%3CSPAN%3ECWTAP%3C%2FSPAN%3E%3CSPAN%3E%E7%9A%84%E7%BD%91%E7%BB%9C%E8%BF%9E%E6%8E%A5%EF%BC%8C%E5%8F%91%E7%8E%B0%E4%BA%86%E4%B8%8E%E6%82%A8%E7%B1%BB%E4%BC%BC%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%8C%E8%AF%B7%E6%A3%80%E6%9F%A5%E6%82%A8%3C%2FSPAN%3E%3CSPAN%3ECWTAP%3C%2FSPAN%3E%3CSPAN%3E%E7%9A%84%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E(bin)%207%20%25%20delete%20all%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E(bin)%208%20%25%20config%20cc%20cwtap%3A10.193.20.174%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E(bin)%209%20%25%20show%20cc%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E0%3A%20Network%20timeout%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3EThere%20are%20no%20command%20converters%20configured%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2141630%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2141630%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%B8%80%E7%9B%B4%E5%AD%98%E5%9C%A8%EF%BC%8C%E5%BB%BA%E8%AE%AE%E4%BD%A0%E6%8D%A2%E4%B8%80%E5%8F%B0%3C%2FSPAN%3E%3CSPAN%3EPC%3C%2FSPAN%3E%3CSPAN%3E%E6%9C%BA%EF%BC%8C%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%3C%2FSPAN%3E%3CSPAN%3ECW%3C%2FSPAN%3E%3CSPAN%3E%E8%AF%95%E4%B8%80%E4%B8%8B%EF%BC%8C%E5%B9%B6%E4%B8%94%E7%A1%AE%E8%AE%A4%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3CSPAN%3ECWTAP%3C%2FSPAN%3E%3CSPAN%3E%E4%B9%8B%E5%89%8D%EF%BC%8C%E8%AE%BE%E5%A4%87%E7%AE%A1%E7%90%86%E5%99%A8%E9%83%BD%E5%8F%AF%E4%BB%A5%E8%AF%86%E5%88%AB%3C%2FSPAN%3E%3CSPAN%3ECWTAP%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%B2%E5%8F%A3%E5%B9%B6%E8%83%BD%E8%BE%93%E5%85%A5%3C%2FSPAN%3E%3CSPAN%3ECWTAP%3C%2FSPAN%3E%3CSPAN%3E%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3E%E5%9B%A0%E4%B8%BA%E6%88%91%E6%89%8B%E4%B8%8A%E7%9A%84%3C%2FSPAN%3E%3CSPAN%3EG%3C%2FSPAN%3E%3CSPAN%3E%E5%92%8C%3C%2FSPAN%3E%3CSPAN%3EH%20%3C%2FSPAN%3E%3CSPAN%3Eversion%3C%2FSPAN%3E%3CSPAN%3E%E9%83%BD%E6%97%A0%E6%B3%95%E5%A4%8D%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3ELX2160ARDBGSG%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%AD%EF%BC%8C%E6%9C%89%E5%AF%B9RCW_SRC%5B3%EF%BC%9A0%5D%E5%92%8CTBSCAN_EN_B%E7%9A%84%E9%85%8D%E7%BD%AE%E6%8F%8F%E8%BF%B0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3ECFG_DRV%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%8D%E7%9F%A5%E9%81%93%E6%82%A8%E6%8C%87%E4%BB%80%E4%B9%88%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140201%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140201%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F204495%22%20target%3D%22_blank%22%3E%40June_Lu%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%3CSPAN%3E%E8%BF%9E%E4%B8%8AG%20version%E5%90%8E%E7%9A%84%E6%95%88%E6%9E%9C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_0-1753363512039.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_0-1753363512039.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349343i208F6544544CE1DF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_0-1753363512039.png%22%20alt%3D%22Zhoute_0-1753363512039.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%BF%98%E6%9C%89%E4%B8%80%E4%BA%9B%E7%A1%AC%E4%BB%B6%E9%97%AE%E9%A2%98%E9%BA%BB%E7%83%A6%E6%82%A8%E7%AD%94%E7%96%91%E4%B8%80%E4%B8%8B%EF%BC%8C%E5%8D%81%E5%88%86%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E1.%E8%BF%9E%E6%8E%A5%E4%BB%BF%E7%9C%9F%E5%99%A8%E6%97%B6RCW_SRC%5B3%EF%BC%9A0%5D%EF%BC%8C%E8%BF%98%E6%9C%89TBSCAN_EN_B%E6%80%8E%E4%B9%88%E9%85%8D%E7%BD%AE%3F%2C%E4%B9%9F%E5%B0%B1%E6%98%AFCFG_DRV%E7%BD%AE%E9%AB%98%E5%BC%80%E5%A7%8B%E9%85%8D%E7%BD%AE%E7%9A%84%E6%97%B6%E5%80%99%EF%BC%8C%E9%85%8D%E7%BD%AE%E5%AE%8C%EF%BC%88%E5%A4%8D%E4%BD%8D%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%89%E8%BF%99%E5%87%A0%E4%B8%AA%E7%AE%A1%E8%84%9A%E5%BA%94%E8%AF%A5%E6%80%8E%E4%B9%88%E5%A4%84%E7%90%86%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%8D%81%E5%88%86%E6%84%9F%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E(bin)%207%25%20delete%20all%3CBR%20%2F%3E(bin)%208%25%20config%20cc%20cwtap%3CBR%20%2F%3E(bin)%209%25%20show%20cc%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AF%8F%E6%AC%A1%E9%83%BD%E8%A6%81%E5%88%A0%E9%99%A4%E6%89%80%E6%9C%89%3CBR%20%2F%3E%E8%BF%9E%E4%B8%8AG%E7%89%88%E6%9C%AC%E8%AF%95%E4%B8%80%E4%B8%8B%EF%BC%8CUSB%E8%BF%9E%E6%8E%A5%EF%BC%8CH%E7%89%88%E6%9C%AC%EF%BC%8Cfirmware%E5%8F%98%E6%9B%B4%E4%BA%86%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140175%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140175%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F204495%22%20target%3D%22_blank%22%3E%40June_Lu%3C%2FA%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%94%A8USB%E7%9B%B4%E6%8E%A5%E8%BF%9E%E6%8E%A5%E5%88%B0PC%E4%B8%8A%EF%BC%8C%E7%94%A8%E4%B8%8B%E9%9D%A2%E7%9A%84%E5%91%BD%E4%BB%A4%EF%BC%8C%E7%BB%93%E6%9E%9C%E5%A6%82%E4%B8%8B%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_0-1753361540331.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_0-1753361540331.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349336i3758E88B11FCE137%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_0-1753361540331.png%22%20alt%3D%22Zhoute_0-1753361540331.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140173%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140173%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%94%A8USB%E7%9B%B4%E6%8E%A5%E8%BF%9E%E6%8E%A5%E5%88%B0PC%E4%B8%8A%EF%BC%8C%E7%94%A8%E4%B8%8B%E9%9D%A2%E7%9A%84%E5%91%BD%E4%BB%A4%EF%BC%8C%E7%9C%8B%E6%98%AF%E5%90%A6%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E(bin)%208%20%25%20config%20cc%20cwtap%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E(bin)%209%20%25%20show%20cc%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140095%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140095%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F204495%22%20target%3D%22_blank%22%3E%40June_Lu%3C%2FA%3E%26nbsp%3B%E6%84%9F%E8%B0%A2%EF%BC%8C%E8%BD%AF%E4%BB%B6%E5%B7%B2%E7%BB%8F%E5%8D%87%E7%BA%A7%E5%88%B0%E6%8C%87%E5%AE%9A%E7%89%88%E6%9C%AC%E4%BA%86%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_0-1753353660039.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_0-1753353660039.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349310iFF5DDD9B2C0CC959%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_0-1753353660039.png%22%20alt%3D%22Zhoute_0-1753353660039.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%90%AF%E5%8A%A8CCS%E5%90%8E%EF%BC%8C%E6%8C%89%E7%85%A7%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E8%BE%93%E5%85%A5%E6%8C%87%E4%BB%A4%EF%BC%8C%E5%87%BA%E7%8E%B0%E5%A6%82%E4%B8%8B%E6%83%85%E5%86%B5%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_1-1753353805264.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_1-1753353805264.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349311iF54A464FB6CD9E12%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_1-1753353805264.png%22%20alt%3D%22Zhoute_1-1753353805264.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E9%97%AE%E8%AF%A5%E5%A6%82%E4%BD%95%E5%AE%9A%E4%BD%8D%E9%97%AE%E9%A2%98%E5%91%A2%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%3E%E8%AF%B7%E5%B0%86%E5%85%B6%E6%9B%B4%E6%96%B0%E8%87%B3%20CodeWarrior%20IDE%2011.5.12%20%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%3E%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6%E7%BD%91%E7%AB%99%E4%B8%8A%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%3EMy%20NXP%20Account-%26gt%3BSoftware-%26gt%3BSoftware%20Licensing%20and%20Support-%26gt%3BView%20accounts-%26gt%3BProduct%20List-%26gt%3BCodeWarrior%20for%20QorIQ%20LS%20Series%20ARMv8%20ISA-%26gt%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%3E%E8%AF%B7%E4%B8%8B%E8%BD%BD%E6%9B%B4%E6%96%B0%E5%8C%85%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%3Ecom.freescale.armv8.11.5.12.GA.Win.updatesite.221209.zip%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%3E%E8%AF%B7%E6%89%93%E5%BC%80%20C%3A%5CFreescale%5CCW4NET_v2020.06%5C%20cw_armv8%5C%20fsl_eclipse.bat%20%E4%B8%AD%E7%9A%84%20CodeWarrior%EF%BC%8C%E7%84%B6%E5%90%8E%E5%AE%89%E8%A3%85%E6%9D%A5%E8%87%AA%20Help-%26gt%3B%20%E5%AE%89%E8%A3%85%E6%96%B0%E8%BD%AF%E4%BB%B6-%26gt%3B%20Add-%26gt%3B%20%E5%AD%98%E6%A1%A3%E4%B8%AD%E7%9A%84%E6%9B%B4%E6%96%B0%E4%BB%A3%E7%A0%81%E5%8C%85%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%20lang%3D%22en-US%22%3E%E7%84%B6%E5%90%8E%E5%B0%9D%E8%AF%95%E6%89%A7%E8%A1%8C%20ccs%20%E5%91%BD%E4%BB%A4%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%20color%3A%20black%3B%22%20lang%3D%22en-US%22%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E7%94%A8%E4%B8%AD%E6%96%87%E5%9B%9E%E7%AD%94%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F204495%22%20target%3D%22_blank%22%3E%40June_Lu%3C%2FA%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E1.%E6%88%91%E5%8F%AF%E4%BB%A5%20ping%20%E5%88%B0%20CWTAP%EF%BC%8C%EF%BC%88Windows-cmd.exe%20%E4%BD%BF%E7%94%A8%20ping%20FSL082481%20%E5%91%BD%E4%BB%A4%EF%BC%8C%E6%B2%A1%E9%97%AE%E9%A2%98%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E2.%E6%88%91%E4%BB%AC%E6%9C%89%E4%B8%A4%E4%B8%AA%20CWTAP%20%E4%BB%BF%E7%9C%9F%E5%99%A8%EF%BC%8C%E4%B8%80%E4%B8%AA%E6%98%AF%3CREV%20h%3D%22%22%2023201440%3D%22%22%3E%20%EF%BC%8C%E5%8F%A6%E4%B8%80%E4%B8%AA%E6%98%AF%3CREV%20g%3D%22%22%2020461200%3D%22%22%3E%3C%2FREV%3E%3C%2FREV%3E%3C%2FP%3E%3CP%3E3.%3CSPAN%3E%20%E6%88%91%E7%9A%84%20CodeWarrior%20IDE%20%E7%89%88%E6%9C%AC%E6%98%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_0-1753338785256.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_0-1753338785256.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349266i5ED53C6105445609%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_0-1753338785256.png%22%20alt%3D%22Zhoute_0-1753338785256.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E6%96%B0%E7%9A%84%E4%BB%A3%E7%A0%81%E5%8C%85%E4%B9%9F%E5%B7%B2%E5%AF%BC%E5%85%A5%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%E6%82%A8%E8%83%BD%20ping%20%E4%B8%80%E4%B8%8B%20CWTAP%20%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%E6%82%A8%E7%9A%84%20CWTAP%20%E7%89%88%E6%9C%AC%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%E6%82%A8%E7%9A%84%20CodeWarrior%20IDE%20%E7%89%88%E6%9C%AC%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139285%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139285%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F204495%22%20target%3D%22_blank%22%3E%40June_Lu%3C%2FA%3E%20%E4%BD%A0%E8%83%BD%E4%B8%8D%E8%83%BD%E6%8A%8A%20CodeWarrior%20Tap%20%E6%A8%A1%E6%8B%9F%E5%99%A8%E7%9A%84%20PIN%20%E5%AE%9A%E4%B9%89%E5%8F%91%E7%BB%99%E6%88%91%EF%BC%88%E5%9C%A8%20Jtag%20%E9%83%A8%E5%88%86%EF%BC%89%EF%BC%9F%E6%88%91%E4%BB%AC%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E9%80%9A%E8%BF%87%E7%89%B9%E5%AE%9A%E4%BF%A1%E5%8F%B7%EF%BC%88TDI%2FTDO%2FTCK%2FTMS%2FRESET%2FVDD%2FGND%EF%BC%89%E8%BF%9E%E6%8E%A5%E7%9B%AE%E6%A0%87%E6%9D%BFlx2080%E3%80%82CodeWarrior%20Tap%20%E6%A8%A1%E6%8B%9F%E5%99%A8%E4%B8%80%E7%9B%B4%E5%9C%A8%E6%98%BE%E7%A4%BA%E4%B8%8A%E8%BF%B0%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E7%82%B9%E5%87%BB%E8%BF%9E%E6%8E%A5%E6%8C%89%E9%92%AE%E6%97%B6%EF%BC%8C%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_0-1753264228307.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_0-1753264228307.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349088i1801B502CB4E4D1A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_0-1753264228307.png%22%20alt%3D%22Zhoute_0-1753264228307.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%80%8C%E4%B8%94%20CodeWarrior%20Tap%20%E6%A8%A1%E6%8B%9F%E5%99%A8%E7%9A%84%E6%8C%87%E7%A4%BA%E7%81%AF%EF%BC%88%E8%BF%90%E8%A1%8C%2F%E6%9A%82%E5%81%9C%EF%BC%89%E4%B8%80%E7%9B%B4%E4%BF%9D%E6%8C%81%E6%A9%99%E8%89%B2%EF%BC%8C%E8%BF%99%E4%B8%8D%E6%98%AF%E5%AE%98%E6%96%B9%E6%96%87%E6%A1%A3%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%E7%BA%A2%E8%89%B2%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%9F%E5%BE%85%E7%9D%80%E6%82%A8%E7%9A%84%E7%AD%94%E5%A4%8D%EF%BC%8C%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3EThe%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8CJune_Lu%EF%BC%8C%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%81%E6%88%91%E7%94%A8%E4%BA%86%E4%BD%A0%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E7%94%A8%EF%BC%8C%E4%B8%8B%E5%9B%BE%E5%B0%B1%E6%98%AF%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%E3%80%82%E6%88%91%E6%90%9C%E7%B4%A2%E4%BA%86%E7%9B%B8%E5%85%B3%E9%94%99%E8%AF%AF%EF%BC%88CC%20%E4%B8%8D%E5%AD%98%E5%9C%A8%EF%BC%89%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhoute_0-1753251599243.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhoute_0-1753251599243.png%22%20style%3D%22width%3A%20369px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348995i38CE290B2828B10E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhoute_0-1753251599243.png%22%20alt%3D%22Zhoute_0-1753251599243.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F204495%22%20target%3D%22_blank%22%3E%40June_Lu%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20CodeWarrior%20Tap%20simulator%20is%20unable%20to%20recognize%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%E5%9C%A8%20CCS%20%E4%B8%AD%EF%BC%8C%E8%AF%B7%E8%BF%90%E8%A1%8C%EF%BC%9A%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E(bin)%207%25%20%E5%88%A0%E9%99%A4%E6%89%80%E6%9C%89%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E(bin)%208%25%20config%20cc%20cwtap%3A10.193.21.52%2F%2F%EF%BC%88%E8%BF%99%E6%98%AF%E6%82%A8%E7%9A%84%20CWTAP%20%E4%BB%A5%E5%A4%AA%E7%BD%91%20IP%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E(bin)%209%25%20show%20cc%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E(bin)%2010%25%20ccs%3A%3Aconfig_chain%20%7Blx2160a%20dap%7D%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E(bin)%2011%25%20display%20%3A%3Accs%3A%3Aget_config_chain%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E(bin)%2012%25%20ccs%3A%3Areset_too_debug%3C%2FP%3E%3C%2FLINGO-BODY%3E
