LS2085A CPU clock reconfiguration
anandhakumarm
I'm using LS2085A processor, in this 8 cpu cores are there, each one running at 1600 MHz, i want to change this into 1800 MHz.. Is there any way to change this by configuring RCW or u-boot ?
Bulat
Core's frequency is set up in the RCW, this is what you need to change.
Bulat
Bulat
Bulat
anandhakumarm
Meanwhile i also found the same. Anyway thank you so much for your valuable reply :smileyhappy:
