LS1088A PLL register documentation
1,456 次查看
Akshay_Redekar
I'm working on LS1088A processor to configure the clock driver for it. I don't see registers "PLL cluster n general status register (Clocking_PLLC1GSR/Clocking_PLLC2GSR/Clocking_PLLPGSR)" in LS1088A RM. As those registers were present under LS1046A RM with detail clocking memory map (along with offsets).
Where can I find the documentation for PLL1/PLL2/PPLL registers for LS1088A ? Also same observed for LS1028A  also.
Currently I used offsets for above registers for LS1088A as per https://github.com/torvalds/linux/blob/master/drivers/clk/clk-qoriq.c. I'm using below multiplier mask -
/// PLL [core] cluster multiplier mask. CGA_PLL1_RAT for LS1028A/LS1088A
#define CG_LS_PLL1C_MULT_MASK (0x1FE00000U)
/// PLL [core] cluster multiplier mask. CGA_PLL2_RAT for LS1028A/LS1088A
#define CG_LS_PLL2C_MULT_MASK (0x000001FEU)
/// Platform PLL multiplier mask. SYS_PLL_RAT for LS1028A/LS1088A
#define CG_LS_PLLP_MULT_MASK (0x7E000000U)
I'm getting issues with boot up in that case for LS1088A. Can someone suggest if the masks used are correct as no documentation available for these in case of LS1028A/LS1088A. PLL [core] cluster multiplier mask 8 BIT and Platform PLL multiplier mask 6 BIT values will be used as per RCW register configuration.
1,367 次查看
SebastianG
Hi @Akshay_Redekar,
Apologies for the delayed response
The masks/// PLL cluster multiplier mask [core]. CGA_PLL1_RAT for LS1028A/LS1088A
/// PLL cluster multiplier mask [core]. CGA_PLL2_RAT for LS1028A/LS1088A
They look correct for use with these registers
1,433 次查看
SebastianG
Hello @Akshay_Redekar
I would like to inform you that I'm working on your question, I will let you know as soon as I have an update.
Thank you so much for your patience
Sebastian
