LS1046 does not boot from USB
2,353件の閲覧回数
douglassilva
I am trying to boot from USB, LS1046 using OK1046A-C2 Single Board Computer from forlinx.
I am flashing the USB using the following command
flex-installer -i auto -m ls1046ardb -d /dev/sdq -p 4P=128M:2G:8G:-1
And it installs into USB successfully(attached file showing instalation finishing successfully)
But then when I connect it to OK1046-C2 board and try to boot these are the kernel messages I get(full boot log attached)
[ 3.169118] usb usb5-port1: couldn't allocate usb_device
[ 3.171636] Actions configured
[ 3.180608] Initializing XFRM netlink socket
[ 3.184913] NET: Registered protocol family 10
[ 3.189787] Segment Routing with IPv6
[ 3.193484] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.199598] NET: Registered protocol family 17
[ 3.204048] NET: Registered protocol family 15
[ 3.208515] Bridge firewalling registered
[ 3.212616] 8021q: 802.1Q VLAN Support v1.8
[ 3.216811] lib80211: common routines for IEEE802.11 drivers
[ 3.222498] 9pnet: Installing 9P2000 support
[ 3.226778] tsn generic netlink module v1 init...
[ 3.231505] Key type dns_resolver registered
[ 3.235924] registered taskstats version 1
[ 3.240028] Loading compiled-in X.509 certificates
[ 3.245675] Btrfs loaded, crc32c=crc32c-generic
[ 3.252135] ALSA device list:
[ 3.255116] No soundcards found.
[ 3.258692] Waiting for root device PARTUUID=6e461725-04...
[ 3.380755] mmc0: new HS200 MMC card at address 0001
[ 3.386048] mmcblk0: mmc0:0001 88A398 7.28 GiB
[ 3.390738] mmcblk0boot0: mmc0:0001 88A398 partition 1 4.00 MiB
[ 3.396812] mmcblk0boot1: mmc0:0001 88A398 partition 2 4.00 MiB
[ 3.402793] mmcblk0rpmb: mmc0:0001 88A398 partition 3 4.00 MiB, chardev (506:0)
[ 3.410929] mmcblk0: p1 p2 p3
[ \00
3 返答(返信)
2,325件の閲覧回数
Oswalag
Which version of LSDK are you testing?
2,320件の閲覧回数
douglassilva
I am testing with LSDK 2108, but I did not had successfull results with 2012 either.
2,347件の閲覧回数
douglassilva
For some reason the attachments were not sent with the post, here they are attached again.
%3CLINGO-SUB%20id%3D%22lingo-sub-2175954%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1046%E3%81%8CUSB%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175954%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eforlinx%20%E3%81%AE%20OK1046A-C2%20%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%9C%E3%83%BC%E3%83%89%20%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81USB%E3%80%81LS1046%20%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6USB%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Eflex-installer%20-i%20%E8%BB%8A%E8%BC%89%20-m%20ls1046ardb%20-d%20%2Fdev%2Fsdq%20-p%204P%3D128M%3A2G%3A8G%3A-1%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6USB%E3%81%AB%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%99%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%89%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81OK1046-C2%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E8%B5%B7%E5%8B%95%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%EF%BC%88%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%82%B0%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%5B%203.169118%5D%20usb%20usb5-port1%3A%20usb_device%20%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%203.171636%5D%20%E3%82%A2%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%203.180608%5D%20XFRM%E3%83%8D%E3%83%83%E3%83%88%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3E%5B%203.184913%5D%20NET%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2010%3CBR%20%2F%3E%20%5B%203.189787%5D%20IPv6%E3%81%AB%E3%82%88%E3%82%8B%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%3CBR%20%2F%3E%5B%203.193484%5D%20sit%3A%20IPv6%E3%80%81IPv4%E3%80%81MPLS%20over%20IPv4%20%E3%83%88%E3%83%B3%E3%83%8D%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3E%5B%203.199598%5D%20NET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2017%3CBR%20%2F%3E%20%5B%203.204048%5D%20NET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2015%3CBR%20%2F%3E%20%5B%203.208515%5D%20%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%95%E3%82%A1%E3%82%A4%E3%82%A2%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%AB%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%203.212616%5D%208021q%3A%20802.1Q%20VLAN%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v1.8%3CBR%20%2F%3E%20%5B%203.216811%5D%20lib80211%3A%20IEEE802.11%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E5%85%B1%E9%80%9A%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%3CBR%20%2F%3E%5B%203.222498%5D%209pnet%3A%209P2000%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3CBR%20%2F%3E%5B%203.226778%5D%20TSN%20%E6%B1%8E%E7%94%A8%E3%83%8D%E3%83%83%E3%83%88%E3%83%AA%E3%83%B3%E3%82%AF%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20v1%20%E5%88%9D%E6%9C%9F%E5%8C%96...%3CBR%20%2F%3E%20%5B%203.231505%5D%20%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97dns_resolver%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%203.235924%5D%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E7%B5%B1%E8%A8%88%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31%3CBR%20%2F%3E%20%5B%203.240028%5D%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9FX.509%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3CBR%20%2F%3E%5B%203.245675%5D%20Btrfs%20%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81crc32c%3Dcrc32c-generic%3CBR%20%2F%3E%20%5B%203.252135%5D%20ALSA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%AA%E3%82%B9%E3%83%88%3A%3CBR%20%2F%3E%20%5B%203.255116%5D%20%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%5B%203.258692%5D%20%E3%83%AB%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20PARTUUID%3D6e461725-04%20%E3%82%92%E5%BE%85%E6%A9%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20%5B%203.380755%5D%20mmc0%3A%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90001%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84HS200%20MMC%E3%82%AB%E3%83%BC%E3%83%89%3CBR%20%2F%3E%5B%203.386048%5D%20mmcblk0%3A%20mmc0%3A0001%2088A398%207.28%20GiB%3CBR%20%2F%3E%20%5B%203.390738%5D%20mmcblk0boot0%3A%20mmc0%3A0001%2088A398%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B31%204.00%20MiB%3CBR%20%2F%3E%20%5B%203.396812%5D%20mmcblk0boot1%3A%20mmc0%3A0001%2088A398%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B32%204.00%20MiB%3CBR%20%2F%3E%20%5B%203.402793%5D%20mmcblk0rpmb%3A%20mmc0%3A0001%2088A398%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B33%204.00%20MiB%E3%80%81chardev%20(506%3A0)%3CBR%20%2F%3E%20%5B%203.410929%5D%20mmcblk0%3A%20p1%20p2%20p3%3CBR%20%2F%3E%20%5B%20%5C00%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1046%20does%20not%20boot%20from%20USB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A7%81%E3%81%AF%20LSDK%202108%20%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%812012%20%E3%81%A7%E3%82%82%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F%E7%B5%90%E6%9E%9C%E3%81%AF%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1046%20does%20not%20boot%20from%20USB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%20LSDK%20%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2175962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1046%20does%20not%20boot%20from%20USB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E6%8A%95%E7%A8%BF%E3%81%A8%E4%B8%80%E7%B7%92%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E5%86%8D%E5%BA%A6%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
