LS1046 does not boot from USB
douglassilva
I am trying to boot from USB, LS1046 using OK1046A-C2 Single Board Computer from forlinx.
I am flashing the USB using the following command
flex-installer -i auto -m ls1046ardb -d /dev/sdq -p 4P=128M:2G:8G:-1
And it installs into USB successfully(attached file showing instalation finishing successfully)
But then when I connect it to OK1046-C2 board and try to boot these are the kernel messages I get(full boot log attached)
[ 3.169118] usb usb5-port1: couldn't allocate usb_device
[ 3.171636] Actions configured
[ 3.180608] Initializing XFRM netlink socket
[ 3.184913] NET: Registered protocol family 10
[ 3.189787] Segment Routing with IPv6
[ 3.193484] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.199598] NET: Registered protocol family 17
[ 3.204048] NET: Registered protocol family 15
[ 3.208515] Bridge firewalling registered
[ 3.212616] 8021q: 802.1Q VLAN Support v1.8
[ 3.216811] lib80211: common routines for IEEE802.11 drivers
[ 3.222498] 9pnet: Installing 9P2000 support
[ 3.226778] tsn generic netlink module v1 init...
[ 3.231505] Key type dns_resolver registered
[ 3.235924] registered taskstats version 1
[ 3.240028] Loading compiled-in X.509 certificates
[ 3.245675] Btrfs loaded, crc32c=crc32c-generic
[ 3.252135] ALSA device list:
[ 3.255116] No soundcards found.
[ 3.258692] Waiting for root device PARTUUID=6e461725-04...
[ 3.380755] mmc0: new HS200 MMC card at address 0001
[ 3.386048] mmcblk0: mmc0:0001 88A398 7.28 GiB
[ 3.390738] mmcblk0boot0: mmc0:0001 88A398 partition 1 4.00 MiB
[ 3.396812] mmcblk0boot1: mmc0:0001 88A398 partition 2 4.00 MiB
[ 3.402793] mmcblk0rpmb: mmc0:0001 88A398 partition 3 4.00 MiB, chardev (506:0)
[ 3.410929] mmcblk0: p1 p2 p3
[ \00
Oswalag
Which version of LSDK are you testing?
douglassilva
I am testing with LSDK 2108, but I did not had successfull results with 2012 either.
douglassilva
For some reason the attachments were not sent with the post, here they are attached again.
%3CLINGO-SUB%20id%3D%22lingo-sub-2175954%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1046%20does%20not%20boot%20from%20USB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175954%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20trying%20to%20boot%20from%20USB%2C%20LS1046%20using%20OK1046A-C2%20Single%20Board%20Computer%20from%20forlinx.%3C%2FP%3E%3CP%3EI%20am%20flashing%20the%20USB%20using%20the%20following%20command%3C%2FP%3E%3CP%3Eflex-installer%20-i%20auto%20-m%20ls1046ardb%20-d%20%2Fdev%2Fsdq%20-p%204P%3D128M%3A2G%3A8G%3A-1%3C%2FP%3E%3CP%3EAnd%20it%20installs%20into%20USB%20successfully(attached%20file%20showing%20instalation%20finishing%20successfully)%3C%2FP%3E%3CP%3EBut%20then%20when%20I%20connect%20it%20to%20OK1046-C2%20board%20and%20try%20to%20boot%20these%20are%20the%20kernel%20messages%20I%20get(full%20boot%20log%20attached)%3C%2FP%3E%3CP%3E%5B%203.169118%5D%20usb%20usb5-port1%3A%20couldn't%20allocate%20usb_device%3CBR%20%2F%3E%5B%203.171636%5D%20Actions%20configured%3CBR%20%2F%3E%5B%203.180608%5D%20Initializing%20XFRM%20netlink%20socket%3CBR%20%2F%3E%5B%203.184913%5D%20NET%3A%20Registered%20protocol%20family%2010%3CBR%20%2F%3E%5B%203.189787%5D%20Segment%20Routing%20with%20IPv6%3CBR%20%2F%3E%5B%203.193484%5D%20sit%3A%20IPv6%2C%20IPv4%20and%20MPLS%20over%20IPv4%20tunneling%20driver%3CBR%20%2F%3E%5B%203.199598%5D%20NET%3A%20Registered%20protocol%20family%2017%3CBR%20%2F%3E%5B%203.204048%5D%20NET%3A%20Registered%20protocol%20family%2015%3CBR%20%2F%3E%5B%203.208515%5D%20Bridge%20firewalling%20registered%3CBR%20%2F%3E%5B%203.212616%5D%208021q%3A%20802.1Q%20VLAN%20Support%20v1.8%3CBR%20%2F%3E%5B%203.216811%5D%20lib80211%3A%20common%20routines%20for%20IEEE802.11%20drivers%3CBR%20%2F%3E%5B%203.222498%5D%209pnet%3A%20Installing%209P2000%20support%3CBR%20%2F%3E%5B%203.226778%5D%20tsn%20generic%20netlink%20module%20v1%20init...%3CBR%20%2F%3E%5B%203.231505%5D%20Key%20type%20dns_resolver%20registered%3CBR%20%2F%3E%5B%203.235924%5D%20registered%20taskstats%20version%201%3CBR%20%2F%3E%5B%203.240028%5D%20Loading%20compiled-in%20X.509%20certificates%3CBR%20%2F%3E%5B%203.245675%5D%20Btrfs%20loaded%2C%20crc32c%3Dcrc32c-generic%3CBR%20%2F%3E%5B%203.252135%5D%20ALSA%20device%20list%3A%3CBR%20%2F%3E%5B%203.255116%5D%20No%20soundcards%20found.%3CBR%20%2F%3E%5B%203.258692%5D%20Waiting%20for%20root%20device%20PARTUUID%3D6e461725-04...%3CBR%20%2F%3E%5B%203.380755%5D%20mmc0%3A%20new%20HS200%20MMC%20card%20at%20address%200001%3CBR%20%2F%3E%5B%203.386048%5D%20mmcblk0%3A%20mmc0%3A0001%2088A398%207.28%20GiB%3CBR%20%2F%3E%5B%203.390738%5D%20mmcblk0boot0%3A%20mmc0%3A0001%2088A398%20partition%201%204.00%20MiB%3CBR%20%2F%3E%5B%203.396812%5D%20mmcblk0boot1%3A%20mmc0%3A0001%2088A398%20partition%202%204.00%20MiB%3CBR%20%2F%3E%5B%203.402793%5D%20mmcblk0rpmb%3A%20mmc0%3A0001%2088A398%20partition%203%204.00%20MiB%2C%20chardev%20(506%3A0)%3CBR%20%2F%3E%5B%203.410929%5D%20mmcblk0%3A%20p1%20p2%20p3%3CBR%20%2F%3E%5B%20%5C00%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1046%20does%20not%20boot%20from%20USB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EI%20am%20testing%20with%20LSDK%202108%2C%20but%20I%20did%20not%20had%20successfull%20results%20with%202012%20either.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1046%20does%20not%20boot%20from%20USB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWhich%20version%20of%20LSDK%20are%20you%20testing%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2175962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1046%20does%20not%20boot%20from%20USB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFor%20some%20reason%20the%20attachments%20were%20not%20sent%20with%20the%20post%2C%20here%20they%20are%20attached%20again.%3C%2FP%3E%3C%2FLINGO-BODY%3E
