LS1046 does not boot from SD card
1,643件の閲覧回数
douglassilva
I am trying to boot from SD card, LS1046 using OK1046A-C2 Single Board Computer from forlinx.
I am flashing the SD card using the following command
flex-installer -i auto -m ls1046ardb -d /dev/sdq -p 4P=128M:2G:8G:-1
And it installs all partitions into SD card successfully(attached file showing instalation finishing successfully)
But then when I connect it to OK1046-C2 board and try to boot these are the kernel messages I get(full boot log attached)
[ 3.108076] mmc0: SDHCI controller on 1560000.esdhc [1560000.esdhc] using ADMA 64-bit
[ 3.108968] Freescale USDPAA process IRQ driver
[ 3.112360] optee: probing for conduit method.
[ 3.125802] optee: revision 2.6
[ 3.126122] optee: initialized driver
[ 3.138321] NET: Registered protocol family 26
[ 3.142792] u32 classifier
[ 3.145510] input device check on
[ 3.149185] Actions configured
[ 3.152903] Initializing XFRM netlink socket
[ 3.157214] NET: Registered protocol family 10
[ 3.162081] Segment Routing with IPv6
[ 3.165785] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.171894] NET: Registered protocol family 17
[ 3.176352] NET: Registered protocol family 15
[ 3.180809] Bridge firewalling registered
[ 3.184924] 8021q: 802.1Q VLAN Support v1.8
[ 3.189111] lib80211: common routines for IEEE802.11 drivers
[ 3.193552] mmc0: error -110 whilst initialising SD card
[ 3.200103] 9pnet: Installing 9P2000 support
[ 3.204387] tsn generic netlink module v1 init...
[ 3.209119] Key type dns_resolver registered
[ 3.213550] registered taskstats version 1
[ 3.217654] Loading compiled-in X.509 certificates
[ 3.223313] Btrfs loaded, crc32c=crc32c-generic
[ 3.229821] ALSA device list:
[ 3.232784] No soundcards found.
[ 3.236370] Waiting for root device PARTUUID=c52a6a85-04...
[ 3.339452] random: crng init done
タグ(1)
2 返答(返信)
1,621件の閲覧回数
Oswalag
Which version of LSDK are you testing?
1,615件の閲覧回数
douglassilva
I am testing with LSDK 2108, but I did not had successfull results with 2012 either.
%3CLINGO-SUB%20id%3D%22lingo-sub-2175961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1046%E3%81%8CSD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81forlinx%20%E3%81%AE%20OK1046A-C2%20%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%9C%E3%83%BC%E3%83%89%20%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81SD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%80%81LS1046%20%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6SD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Eflex-installer%20-i%20%E8%BB%8A%E8%BC%89%20-m%20ls1046ardb%20-d%20%2Fdev%2Fsdq%20-p%204P%3D128M%3A2G%3A8G%3A-1%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%20SD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%20(%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81OK1046-C2%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E8%B5%B7%E5%8B%95%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%EF%BC%88%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%82%B0%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%5B%203.108076%5D%20mmc0%3A%201560000.esdhc%20%E4%B8%8A%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20%5B1560000.esdhc%5DADMA%2064%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3E%5B%203.108968%5D%20Freescale%20USDPAA%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9IRQ%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3E%5B%203.112360%5D%20optee%3A%20%E5%B0%8E%E7%AE%A1%E6%96%B9%E6%B3%95%E3%81%AE%E8%AA%BF%E6%9F%BB%E3%80%82%3CBR%20%2F%3E%5B%203.125802%5D%20optee%3A%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%202.6%3CBR%20%2F%3E%5B%203.126122%5D%20optee%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3E%5B%203.138321%5D%20NET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2026%3CBR%20%2F%3E%5B%203.142792%5D%20u32%E5%88%86%E9%A1%9E%E5%99%A8%3CBR%20%2F%3E%5B%203.145510%5D%20%E5%85%A5%E5%8A%9B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%AA%E3%83%B3%3CBR%20%2F%3E%5B%203.149185%5D%20%E3%82%A2%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%203.152903%5D%20XFRM%E3%83%8D%E3%83%83%E3%83%88%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3E%5B%203.157214%5D%20NET%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2010%3CBR%20%2F%3E%5B%203.162081%5D%20IPv6%E3%81%AB%E3%82%88%E3%82%8B%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%3CBR%20%2F%3E%5B%203.165785%5D%20sit%3A%20IPv6%E3%80%81IPv4%E3%80%81MPLS%20over%20IPv4%20%E3%83%88%E3%83%B3%E3%83%8D%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3E%5B%203.171894%5D%20NET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2017%3CBR%20%2F%3E%5B%203.176352%5D%20NET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2015%3CBR%20%2F%3E%5B%203.180809%5D%20%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%95%E3%82%A1%E3%82%A4%E3%82%A2%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%AB%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%203.184924%5D%208021q%3A%20802.1Q%20VLAN%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v1.8%3CBR%20%2F%3E%5B%203.189111%5D%20lib80211%3A%20IEEE802.11%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E5%85%B1%E9%80%9A%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%3CBR%20%2F%3E%5B%203.193552%5D%20mmc0%3A%20SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%20-110%20%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%203.200103%5D%209pnet%3A%209P2000%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3CBR%20%2F%3E%5B%203.204387%5D%20TSN%20%E6%B1%8E%E7%94%A8%E3%83%8D%E3%83%83%E3%83%88%E3%83%AA%E3%83%B3%E3%82%AF%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20v1%20%E5%88%9D%E6%9C%9F%E5%8C%96...%3CBR%20%2F%3E%5B%203.209119%5D%20%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97dns_resolver%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%203.213550%5D%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E7%B5%B1%E8%A8%88%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31%3CBR%20%2F%3E%5B%203.217654%5D%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9FX.509%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3CBR%20%2F%3E%5B%203.223313%5D%20Btrfs%20%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81crc32c%3Dcrc32c-generic%3CBR%20%2F%3E%5B%203.229821%5D%20ALSA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%AA%E3%82%B9%E3%83%88%3A%3CBR%20%2F%3E%5B%203.232784%5D%20%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%5B%203.236370%5D%20%E3%83%AB%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20PARTUUID%3Dc52a6a85-04%20%E3%82%92%E5%BE%85%E6%A9%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20%5B%203.339452%5D%20%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%3A%20crng%20init%20%E5%AE%8C%E4%BA%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176273%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1046%20does%20not%20boot%20from%20SD%20card%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176273%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A7%81%E3%81%AF%20LSDK%202108%20%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%812012%20%E3%81%A7%E3%82%82%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F%E7%B5%90%E6%9E%9C%E3%81%AF%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1046%20does%20not%20boot%20from%20SD%20card%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%20LSDK%20%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
