secondary USB bootloader example on LPCXpresso 1769
1,060 次查看
lpcware
Content originally posted in LPCWare by Gordon on Tue Feb 22 01:43:54 MST 2011
I am wondering if there is any example code for USB bootloader on LPCXpresso 1769. So far, I have only found some code intended for Keil which I am not able to compile in LPCXpresso. Any suggestions on this please?
903 次查看
lpcware
Content originally posted in LPCWare by Gordon on Tue Feb 22 03:01:37 MST 2011
Thanks, it seems the problem is solved.
903 次查看
lpcware
Content originally posted in LPCWare by CodeRedSupport on Tue Feb 22 02:31:44 MST 2011
The RDB1768cmsis examples, supplied with LPCXpresso, contains a usb_bootloader example. This will require a minimal amount of porting to LPCXpresso (LPC1768 is the same as a LPC1769 but with a slower maximum clock speed).
