porting Emwin to LPC1549 / LPC1768
2,046 次查看
allwyn
we are working on LPC1549 with a TFT LCD display. i understand that NXP provides pre-compiled  lib of emWin.Is there  any beginner guide to port the same on cortex M3 .Display has ili9481 display controller
We use IDE-MCUxpresso
Please share Any application  note /successful project links/information .
标签 (3)
1,780 次查看
kerryzhou
Hi ALLWYYN ANTONY,
   Yes, we have the application note and the emwin sample code for LPC1769, please refer to these link:
  1. https://www.nxp.com/docs/en/application-note/AN11244.pdf
   2. Code issue solutions in emWin_mcb1700_bsp
   The sample code is using the LPXpresso IDE, but don't worry, the MCXpress IDE totally compatible with the LCXpresso IDE, you can open the LPCXpesso IDE project with MCUXpresso IDE directly.
Please try it on your side.
Kerry
