how to set up several adc channels for periodic conversion using M33 core and LPC5506
2,812 次查看
Kratz
I am trying to understand how to set up 6 adc channels for periodic conversion as a group on the LPC5506, M33 core. I am used setting up a FIFO array on a Kinetis MKE02Z micro to automatically let the micro perform a batch of conversions.
The example projects set up one channel and perform a conversion. It seems hard to believe for a group conversion of the 6 adc channels that each channel needs to be set up before each and every conversion.
Would you please shed some light on how to perform periodic conversion for a group of adc channels?
2,757 次查看
Hello @Kratz
I see the same question with your private ticket, so replied you with that case, please check,thanks.
Alice
2,708 次查看
danielholala
Senior Contributor II
I think "lxp5506" might be a typo as I did not find any information about that alleged MCU.
Did you mean "lpc5506" instead?
2,758 次查看
Hello @Kratz
Alice
2,699 次查看
danielholala
Would be nicer to have the answer here for the benefit of the community.
