cgi page is not loading and it get me 404 error why?
3,013件の閲覧回数
navidansari
hi
I have a CGI page that looks like this
t <html><head><title>LED Control</title>
t <script language=JavaScript>
t function AllSW(st) {for(i=0;i<document.form1.length;i++) {
t   if(document.form1.elements[i].type=="checkbox"){
t    document.form1.elements[i].checked=st;
t   }}
t  document.form1.submit();
t }
t </script></head>
i pg_header.inc
t <h2 align=center><br>Control LEDs on the board</h2>
t <p><font size="2">This page shows you how to use the following http form <b>input</b> objects:
t  <b>checkbox</b>, <b>select</b> and <b>button</b>. It uses also a simple <b>Java Script</b>
t  function to check/uncheck all checkboxes and submit the data.<br><br>
t  This Form uses a <b>POST</b> method to send data to a Web server.</font></p>
t <form action=leds.cgi method=post name=form1>
t <input type=hidden value="led" name=pg>
t <table border=0 width=99%><font size="3">
t <tr bgcolor=#aaccff><th width=40%>Item</th><th width=60%>Setting</th></tr>
t <td><img src=pabb.gif>LED control:</td>
t <td><select name="ctrl" onchange="submit();">
c b c <option %s>Browser</option><option %s>Running Lights</option></select></td></tr>
t <tr><td><img src=pabb.gif>LED diode ports [7..0]:</td>
t <td><table><tr valign="middle">
# Here begin the 'checkbox' definitions
c b 7 <td> <button type="button" name = "button" onclick="submit();">Click Me!</button></td>
c b 6 <td><input type="text" name="firstname"><br></td>
c b 5 <td><input type=checkbox name=led5 OnClick="submit();" %s>5</td>
c b 4 <td><input type=checkbox name=led4 OnClick="submit();" %s>4</td>
t <td width="5%"></td>
c b 3 <td><input type=checkbox name=led3 OnClick="submit();" %s>3</td>
c b 2 <td><input type=checkbox name=led2 OnClick="submit();" %s>2</td>
c b 1 <td><input type=checkbox name=led1 OnClick="submit();" %s>1</td>
c b 0 <td><input type=checkbox name=led0 OnClick="submit();" %s>0</td>
t </font></table></td></tr>
t <tr><td><img src=pabb.gif>All LED diodes On or OFF</td>
t <td><input type=button value="  ON   " onclick="AllSW(true)">
t <input type=button value="  OFF  " onclick="AllSW(false)"></td></tr>
t </table></form>
i pg_footer.inc
. End of script must be closed with period.
and i have index.html that looks like this
 <a href="/leds.cgi">
     LED
 </a>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
it's just a link to a cgi file
index.html is running fine but when i try to run leds.CGI it's not working anymore
im using network core 7.5.0
yes i added CGI file to the web folder
it get me this error
HTTP/1.1 404 Not Found Server: Keil-EWEB/2.1 Content-type: text/html Connection: close
Error 404 - Not Found
The requested URL was not found on this server.
タグ(2)
2,693件の閲覧回数
navidansari
hi
LPC1768
i solve it
in net request, i should return the value that passing to me
and another thing
header and ffoter in example cause the error
so it solved thanks
2,693件の閲覧回数
soledad
Which device are you using?
Are you using some LPCOpen example?
Soledad
2,694件の閲覧回数
navidansari
hi
LPC1768
i solve it
and another thing
so it solved thanks
