What opens the PCB Layout file, for the OM13097 Eval Board?
19,595 次查看
morechnikov
I've downloaded the design files for the OM13097 Eval Board (LPC845 MCU). Within these files, lies a layout .zip -- containing the .pcb file. I've tried to view this file, with: Circuitmaker 2000, KiCAD, Cadence Allegro Viewer, Altium and Easy EDA. However, none of them have managed to open the file.
What is the preferred environment for viewing this PCB layout? Are there any recommendations?
标记 (3)
19,449 次查看
7 回复数
19,564 次查看
morechnikov
Apologies for the double post,
We may not have the full environment required to open the design files. Is it possible to send a pdf, or even an image, of both sides of the OM13097 PCB? Just to see the tracks beneath the LPC?
Much appreciated,
Mike
19,482 次查看
Hello @morechnikov
Yes, the schematic of PDF you can find under folder "LPCXpresso845MAX-Board",
I also attach it  for you.
Alice
19,458 次查看
morechnikov
Hello Alice,
I apologize for the confusion. I can open the schematic, but I cannot open the ".pcb" file. Which, I think, contains the physical layout for the eval board. If it does not, and is simply a drawing of the schematic: let me know.
I'll definitely give the schematic another look. However, if you can send me a pdf of the ".pcb" file (both sides of the eval board), or recommend a program to open it -- that would be most appreciated.
Thank you for your time,
Mike
19,450 次查看
Hello @morechnikov
How about use PADS:
https://eda.sw.siemens.com/en-US/pcb/pads/
Alice
19,430 次查看
morechnikov
I tried using PADS (version screenshot, attached), but it faulted when attempting to open the ".pcb" file (error screenshot, attached).
Is it possible "LPC845_Rev2_170328.pcb" is corrupted? Can you open it, on your end?
I can work with simple pictures of each of the board's layers, too.
Mike
EDIT: My colleague got a different version of PADS and we opened the .pcb just fine. Thank you for your help!
19,577 次查看
Hello @morechnikov
Cadence can not open  it?
Do you open the file of "SCH-LPCX84X_MAX_REV-2.dsn"?
Alice
19,568 次查看
morechnikov
Thanks for the quick reply,
When I try to open the "SCH-LPCX84X_MAX_REV-2.dsn" file, I get an error ("database is corrupted", see attached). I am using Allegro Free Physical Viewer 16.6.
My colleague managed to open that .dsn file with Altium Circuit Maker, but not the .pcb file.
Mike
