UART for lpc2148
UART for lpc2148
1,612件の閲覧回数
Content originally posted in LPCWare by rushin010 on Mon Oct 13 09:24:50 MST 2014
IN my college i have keil MCB2140 board. i am using UART0. my code run in keil simulink. i have enabled J1 and J10 jumper on. jumper J8 and J9 disable. when i am using flash magic to verify connection i get error ' unable to communicate .ensure no other applications are using COM port. try raising or lowering baud rate. i am using rs232 to usb converter
1,513件の閲覧回数
Content originally posted in LPCWare by mazaumesh on Thu Feb 25 07:41:00 MST 2016
Hello Rushin
Here is wonderful post with example project to use UART0 in LPC2148 ARM7 Microcontroller:
http://www.binaryupdates.com/uart-in-lpc2148-arm7/
I am sure you will get all of your answer after reading this post
Have a great time with LPC2148
CHeers
