Read Device Serial Number (22xx)
1,493件の閲覧回数
lpcware
Content originally posted in LPCWare by GuilhermeLizardo on Fri Jul 24 07:21:47 MST 2015
I will implement a new validation process in an protocol between two microcontrollers and I need an  unrepeatable number.  I suppose the Serial Number from chip is unrepeatable , so I suppose be a good way to solve this issue.
I read about this issue in this topic: https://www.lpcware.com/content/forum/read-serial-number but I don't found nothing about 22XX (Arm 7).
How can I obtain this number in 22XX family?
2 返答(返信)
1,391件の閲覧回数
lpcware
Content originally posted in LPCWare by R2D2 on Fri Jul 24 09:23:37 MST 2015
There's no Serial Number in LPC22xx  :((
1,391件の閲覧回数
lpcware
Content originally posted in LPCWare by mysepp on Fri Jul 24 09:14:15 MST 2015
Are you sure the LPC22XX has a unique serial number?
Have you checked User Manual/Datasheet?
Usually FlashMagic allows to read and display the serial. Can you check if this is possible? If yes,
then you know there is one and second step is to find a way to read it.
