Any advice on typical LPC23xx schematics?
1,724 次查看
lpcware
Content originally posted in LPCWare by Мария Смирницкая on Mon Apr 20 05:44:20 MST 2015
I've recently started programming LPC2368 using Keil simulator, and it goes rather well, but now it's time to try a real device, and my boss wants to go with  minimalistic schematics without an evaluation board. We do have three "naked" LPC's, and I need a "typical" schematics of developing a minimalistic board - with power supply, USB, UART0 and JTAG on it, no fancy display, sound output or some "blinky"  stuff. So, is there any tutorial on board developing, or I evaluation board is the only way?
标签 (1)
3 回复数
1,616 次查看
lpcware
Content originally posted in LPCWare by R2D2 on Tue Apr 21 03:44:27 MST 2015
Quote: Мария Смирницкая
I am just a C coder, not a desicion maker. But I take it - there's no such thing as "typical layout", "typical schematic", or "minimalistic board development tutorial" ?
LPC23xx isn't a simple transistor  :)
Usually the board designer is deciding what is included / excluded on the board (with datasheet and user manual)  :O
If you are not familiar with this things it's usually easier to buy a working board...
http://mcuzone.en.alibaba.com/product/282106478-212350565/LPC2368_Mini_Board_NXP_ARM7_.html
If you are trying to draw your own board it's useful to look at other DEV-boards and exclude things you don't need  :)
Something like:
http://www.micro4you.com/files/lpc2368/ARM7_LPC2368.pdf
1,616 次查看
lpcware
Content originally posted in LPCWare by Мария Смирницкая on Tue Apr 21 02:31:32 MST 2015
1,616 次查看
lpcware
Content originally posted in LPCWare by R2D2 on Mon Apr 20 05:51:40 MST 2015
I've recently started programming LPC2368...
I would suggest to use a modern MCU (LPC1768) and look at LPCXpresso1768 board schematic (or other Dev-boards)...
