SYSCON_PDRUNCFG_PD_IRC_OSC vs SYSCON_PDRUNCFG_PD_IRC
已解决
跳至解决方案
2,487 次查看
simonwyss
What is the difference between these two Power Switches?
LPCopen file: syscon_5410x.h
标签 (1)
1 解答
2,369 次查看
jeremyzhou
Hi Simon Wyss,
for the opportunity to serve you.
Keep mind: To enable the IRC oscillator, these two bits should work together, they're inseparable.
TIC
在原帖中查看解决方案
2 回复数
2,370 次查看
jeremyzhou
Hi Simon Wyss,
TIC
2,369 次查看
simonwyss
Hi jeremyzhou
Thank you for your reply!
