LPCScrypt Can not work
2,636 次查看
wsinter
Hello,I used the LPCScrypt for lpc4330, but it can not work.
It has booted successfully,but says no serial port,actually the com port is already exist.
Attachment is the screen shot.
Please help for the problem why it can not find the serial port.
1,241 次查看
jeremyzhou
Hi John Wang,
for the opportunity to serve you.
I'd highly recommend you to use the most updated LPCScrypt instead the version you use, then give a try again.
LPCScrypt v1.8.2|NXP
TIC
