LPC55S36 XTAL32M with External Oscillator
BrKu
Good morning,
I am trying to drive the external high speed oscillator XTAL32M on the LPC55S36 with an oscillator rather than a crystal.  The datasheet section 13.2 warns that this input should stay below 850mV.  I can't find any oscillators that output voltages that low -- is there a recommended part / circuit to achieve this?
Thank you.
Omar_Anguiano
You can add a voltage divider to achieve the voltage requirement.
BR,
Omar
%3CLINGO-SUB%20id%3D%22lingo-sub-2157646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC55S36%20XTAL32M%20with%20External%20Oscillator%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGood%20morning%2C%3C%2FP%3E%3CP%3EI%20am%20trying%20to%20drive%20the%20external%20high%20speed%20oscillator%26nbsp%3BXTAL32M%20on%20the%20LPC55S36%20with%20an%20oscillator%20rather%20than%20a%20crystal.%26nbsp%3B%20The%20datasheet%20section%2013.2%20warns%20that%20this%20input%20should%20stay%20below%20850mV.%26nbsp%3B%20I%20can't%20find%20any%20oscillators%20that%20output%20voltages%20that%20low%20--%20is%20there%20a%20recommended%20part%20%2F%20circuit%20to%20achieve%20this%3F%3C%2FP%3E%3CP%3EThank%20you.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2157646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC55xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55S36%20XTAL32M%20with%20External%20Oscillator%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYou%20can%20add%20a%20voltage%20divider%20to%20achieve%20the%20voltage%20requirement.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EBR%2C%3CBR%20%2F%3EOmar%3C%2FP%3E%3C%2FLINGO-BODY%3E
