LPC55S36 XTAL32M with External Oscillator
BrKu
Good morning,
I am trying to drive the external high speed oscillator XTAL32M on the LPC55S36 with an oscillator rather than a crystal.  The datasheet section 13.2 warns that this input should stay below 850mV.  I can't find any oscillators that output voltages that low -- is there a recommended part / circuit to achieve this?
Thank you.
Omar_Anguiano
You can add a voltage divider to achieve the voltage requirement.
BR,
Omar
