LPC55S28 USB HS Receiver sensitivity Test
1,402 次查看
hskating
NXP team
When I used the LPC55S28 chip to make a product using high-speed usb, after the software function was basically completed, I began to conduct USB authentication Test, and encountered a problem about the Receiver sensitivity Test Reference. It looks something like this:
usb2.0 electrical test failure: High-speed devices must implement a transmission envelope detector that does not display suppression (that is, reliably receive packets) when the receiver differential amplitude exceeds 150mV.
Pass limit: <= 200.000 mVDevice
Please see the attachment for details.
How do I fix this?
I sincerely hope that the NXP team can give me advice and support in this regard.
Thank you from the bottom of my heart.
1,360 次查看
Hello @hskating
Please check the hardware as follows:
Check the D+/D- differential lines. Ensure they are kept away from high - frequency sources such as clock lines and power switches.
Please check the capacitor on the USB_VDD pin. Place it close to the chip. You can refer to the schematic of the lpcxpresso55s28 - evk board.
Allocate a separate ground layer for the USB PHY.
You can also use a USB analyzer to monitor the communication process signal.
Alice
1,361 次查看
Hello @hskating
Alice
%3CLINGO-SUB%20id%3D%22lingo-sub-2074949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC55S28%20USB%20HS%E6%8E%A5%E6%94%B6%E5%99%A8%E7%81%B5%E6%95%8F%E5%BA%A6%E6%B5%8B%E8%AF%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2074949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E5%9B%A2%E9%98%9F%3CBR%20%2F%3E%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8LPC55S28%E8%8A%AF%E7%89%87%E5%88%B6%E4%BD%9C%E4%B8%80%E4%B8%AA%E4%BD%BF%E7%94%A8%E9%AB%98%E9%80%9FUSB%E7%9A%84%E4%BA%A7%E5%93%81%E6%97%B6%EF%BC%8C%E5%9C%A8%E8%BD%AF%E4%BB%B6%E5%8A%9F%E8%83%BD%E5%9F%BA%E6%9C%AC%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8C%E5%BC%80%E5%A7%8B%E8%BF%9B%E8%A1%8CUSB%E8%AE%A4%E8%AF%81%E6%B5%8B%E8%AF%95%EF%BC%8C%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E5%85%B3%E4%BA%8E%E6%8E%A5%E6%94%B6%E7%81%B5%E6%95%8F%E5%BA%A6%E6%B5%8B%E8%AF%95%E5%8F%82%E8%80%83%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E5%AE%83%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%83%8F%E8%BF%99%E6%A0%B7%EF%BC%9A%3CBR%20%2F%3E%20usb2.0%E7%94%B5%E6%B0%94%E6%B5%8B%E8%AF%95%E5%A4%B1%E8%B4%A5%EF%BC%9A%E9%AB%98%E9%80%9F%E8%AE%BE%E5%A4%87%E5%BF%85%E9%A1%BB%E5%AE%9E%E7%8E%B0%E4%B8%80%E4%B8%AA%E4%BC%A0%E8%BE%93%E5%8C%85%E7%BB%9C%E6%A3%80%E6%B5%8B%E5%99%A8%EF%BC%8C%E5%BD%93%E6%8E%A5%E6%94%B6%E5%99%A8%E5%B7%AE%E5%88%86%E5%B9%85%E5%BA%A6%E8%B6%85%E8%BF%87150mV%E6%97%B6%EF%BC%8C%E8%AF%A5%E6%A3%80%E6%B5%8B%E5%99%A8%E4%B8%8D%E4%BC%9A%E6%98%BE%E7%A4%BA%E6%8A%91%E5%88%B6%EF%BC%88%E5%8D%B3%E5%8F%AF%E9%9D%A0%E5%9C%B0%E6%8E%A5%E6%94%B6%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E9%80%9A%E8%BF%87%E9%99%90%E5%88%B6%EF%BC%9A%26lt%3B%3D%20200.000%20mVDevice%3CBR%20%2F%3E%E8%AF%A6%E6%83%85%E8%AF%B7%E5%8F%82%E9%98%85%E9%99%84%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%AF%A5%E5%A6%82%E4%BD%95%E4%BF%AE%E5%A4%8D%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3CBR%20%2F%3E%E6%88%91%E7%9C%9F%E8%AF%9A%E5%B8%8C%E6%9C%9BNXP%E5%9B%A2%E9%98%9F%E8%83%BD%E5%A4%9F%E5%9C%A8%E8%BF%99%E6%96%B9%E9%9D%A2%E7%BB%99%E4%BA%88%E6%88%91%E5%BB%BA%E8%AE%AE%E5%92%8C%E6%94%AF%E6%8C%81%E3%80%82%3CBR%20%2F%3E%E6%88%91%E8%A1%B7%E5%BF%83%E6%84%9F%E8%B0%A2%E4%BD%A0%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
