LPC55S28 USB HS Receiver sensitivity Test
1,509件の閲覧回数
hskating
NXP team
When I used the LPC55S28 chip to make a product using high-speed usb, after the software function was basically completed, I began to conduct USB authentication Test, and encountered a problem about the Receiver sensitivity Test Reference. It looks something like this:
usb2.0 electrical test failure: High-speed devices must implement a transmission envelope detector that does not display suppression (that is, reliably receive packets) when the receiver differential amplitude exceeds 150mV.
Pass limit: <= 200.000 mVDevice
Please see the attachment for details.
How do I fix this?
I sincerely hope that the NXP team can give me advice and support in this regard.
Thank you from the bottom of my heart.
1,467件の閲覧回数
Hello @hskating
Please check the hardware as follows:
Check the D+/D- differential lines. Ensure they are kept away from high - frequency sources such as clock lines and power switches.
Please check the capacitor on the USB_VDD pin. Place it close to the chip. You can refer to the schematic of the lpcxpresso55s28 - evk board.
Allocate a separate ground layer for the USB PHY.
You can also use a USB analyzer to monitor the communication process signal.
Alice
1,467件の閲覧回数
Hello @hskating
Alice
%3CLINGO-SUB%20id%3D%22lingo-sub-2074949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC55S28%20USB%20HS%20%E3%83%AC%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AE%E6%84%9F%E5%BA%A6%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2074949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%83%81%E3%83%BC%E3%83%A0%3CBR%20%2F%3ELPC55S28%E3%83%81%E3%83%83%E3%83%97%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E9%AB%98%E9%80%9FUSB%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%9F%E8%A3%BD%E5%93%81%E3%82%92%E4%BD%9C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E6%A9%9F%E8%83%BD%E3%81%8C%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E5%AE%8C%E6%88%90%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81USB%E8%AA%8D%E8%A8%BC%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E8%A1%8C%E3%81%84%E5%A7%8B%E3%82%81%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81Receiver%20sensitivity%20Test%20Reference%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%94%9F%E3%81%98%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%9A%3CBR%20%2F%3Eusb2.0%E3%81%AE%E9%9B%BB%E6%B0%97%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E5%A4%B1%E6%95%97%EF%BC%9A%E9%AB%98%E9%80%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%81%AF%E3%80%81%E5%8F%97%E4%BF%A1%E6%A9%9F%E3%81%AE%E5%B7%AE%E6%8C%AF%E5%B9%85%E3%81%8C150mV%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%82%82%E6%8A%91%E5%88%B6%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%AA%E3%81%84%EF%BC%88%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E7%A2%BA%E5%AE%9F%E3%81%AB%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%EF%BC%89%E9%80%81%E4%BF%A1%E3%82%A8%E3%83%B3%E3%83%99%E3%83%AD%E3%83%BC%E3%83%97%E6%A4%9C%E5%87%BA%E5%99%A8%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%91%E3%82%B9%E5%88%B6%E9%99%90%3A%20%26lt%3B%3D%20200.000%20mVDevice%3CBR%20%2F%3E%E8%A9%B3%E7%B4%B0%E3%81%AF%E5%88%A5%E7%B4%99%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%93%E3%82%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E7%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81NXP%E3%83%81%E3%83%BC%E3%83%A0%E3%81%8B%E3%82%89%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%BF%83%E3%81%8B%E3%82%89%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BF%83%E3%81%8B%E3%82%89%E6%84%9F%E8%AC%9D%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
