LPC55S28 USB HS Receiver sensitivity Test
hskating
NXP team
When I used the LPC55S28 chip to make a product using high-speed usb, after the software function was basically completed, I began to conduct USB authentication Test, and encountered a problem about the Receiver sensitivity Test Reference. It looks something like this:
usb2.0 electrical test failure: High-speed devices must implement a transmission envelope detector that does not display suppression (that is, reliably receive packets) when the receiver differential amplitude exceeds 150mV.
Pass limit: <= 200.000 mVDevice
Please see the attachment for details.
How do I fix this?
I sincerely hope that the NXP team can give me advice and support in this regard.
Thank you from the bottom of my heart.
Hello @hskating
Please check the hardware as follows:
Check the D+/D- differential lines. Ensure they are kept away from high - frequency sources such as clock lines and power switches.
Please check the capacitor on the USB_VDD pin. Place it close to the chip. You can refer to the schematic of the lpcxpresso55s28 - evk board.
Allocate a separate ground layer for the USB PHY.
You can also use a USB analyzer to monitor the communication process signal.
Alice
Hello @hskating
Alice
%3CLINGO-SUB%20id%3D%22lingo-sub-2074949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC55S28%20USB%20HS%20Receiver%20sensitivity%20Test%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2074949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%20team%3CBR%20%2F%3EWhen%20I%20used%20the%20LPC55S28%20chip%20to%20make%20a%20product%20using%20high-speed%20usb%2C%20after%20the%20software%20function%20was%20basically%20completed%2C%20I%20began%20to%20conduct%20USB%20authentication%20Test%2C%20and%20encountered%20a%20problem%20about%20the%20Receiver%20sensitivity%20Test%20Reference.%20It%20looks%20something%20like%20this%3A%3CBR%20%2F%3Eusb2.0%20electrical%20test%20failure%3A%20High-speed%20devices%20must%20implement%20a%20transmission%20envelope%20detector%20that%20does%20not%20display%20suppression%20(that%20is%2C%20reliably%20receive%20packets)%20when%20the%20receiver%20differential%20amplitude%20exceeds%20150mV.%3CBR%20%2F%3EPass%20limit%3A%20%26lt%3B%3D%20200.000%20mVDevice%3CBR%20%2F%3EPlease%20see%20the%20attachment%20for%20details.%3C%2FP%3E%3CP%3EHow%20do%20I%20fix%20this%3F%3CBR%20%2F%3EI%20sincerely%20hope%20that%20the%20NXP%20team%20can%20give%20me%20advice%20and%20support%20in%20this%20regard.%3CBR%20%2F%3EThank%20you%20from%20the%20bottom%20of%20my%20heart.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2078956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPC55S28%20USB%20HS%20Receiver%20sensitivity%20Test%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2078956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F244170%22%20target%3D%22_blank%22%3E%40hskating%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CDIV%20class%3D%22auto-hide-last-sibling-br%20paragraph-qzbcQC%20paragraph-element%20br-paragraph-space%22%3EPlease%20check%20the%20hardware%20as%20follows%3A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22auto-hide-last-sibling-br%20paragraph-qzbcQC%20paragraph-element%20br-paragraph-space%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3ECheck%20the%20D%2B%2FD-%20differential%20lines.%20Ensure%20they%20are%20kept%20away%20from%20high%20-%20frequency%20sources%20such%20as%20clock%20lines%20and%20power%20switches.%3C%2FP%3E%0A%3CP%3EPlease%20check%20the%20capacitor%20on%20the%20USB_VDD%20pin.%20Place%20it%20close%20to%20the%20chip.%20You%20can%20refer%20to%20the%20schematic%20of%20the%20lpcxpresso55s28%20-%20evk%20board.%3C%2FP%3E%0A%3CP%3EAllocate%20a%20separate%20ground%20layer%20for%20the%20USB%20PHY.%3C%2FP%3E%0A%3CP%3EYou%20can%20also%20use%20a%20USB%20analyzer%20to%20monitor%20the%20communication%20process%20signal.%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EAlice%3C%2FP%3E%3C%2FLINGO-BODY%3E
