LPC54S018-EVK recovery after selecting the external clock as system clock
6,382 次查看
p_mamatis
Hey i messed up my LXPpresso54S018-EVK by selecting the external oscillator as system clock.
Now the debugger cant find the SWD connection anymore.
I already tried to get back the access with the ISPconnect script, but it didn't work. (https://community.nxp.com/t5/LPCXpresso-IDE-FAQs/ISP-Reset-over-debug/m-p/470945)
Also the flashmagic stuff doesn't work:
https://community.nxp.com/t5/LPC-Microcontrollers-Knowledge/Flash-Magic-Programing-LPC/ta-p/1152763
I found a recovery guide for a different board:
https://community.nxp.com/t5/i-MX-RT/No-SWD-available-on-RT1064-EVK-now/td-p/911623
So my question  is there something similar to this guide  for the LXPpresso54S018-EVK?
every help is welcome, i am desperate at the moment.
greetings Paul
6,359 次查看
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, I made this document maybe this could help you.
Pavel
6,360 次查看
Pavel_Hernandez
Pavel
6,332 次查看
p_mamatis
Thank you so much Pavel!
I would say i owe you a drink
The guide worked for me!
I needed to make minor adaptation because of another evaluation kit model, but in the end it was easy.
I uploaded a commented version of the guide for people hitting this subject with the same issue and EVK.
Maybe the comments can prevent frustration and save some time
Paul
