KEIL Software pack installer LPC2103
7,319 次查看
oykr
Hi. Have an old board that I need to write code for an LPC2103. Accoridn to ARM KEIL uVISION supports the LPC2103 https://www.keil.com/dd/chip/3974.htm but I cannot find it in the PACK INSTALLER device list. Do I manully need to add the LPC2103 software packs?
标记 (3)
7,289 次查看
Hello @oykr
Device family packs have only been created for Cortex-M based devices. For these older devices  the "legacy support" files need to be installed:
https://developer.arm.com/documentation/101407/0541/Creating-Applications/Tips-and-Tricks/Use-MDK-Ve...
Kind regards,
Alice
4 回复数
7,299 次查看
Hello @oykr
I have already submitted the issue to ARM. I will send you with any updates. You can also ask arm if have any other issue with KEIL.
Alice
7,290 次查看
Hello @oykr
Kind regards,
Alice
6,511 次查看
oykr
I  downloaded and installed the leacy pack for
But I can still not see it in my DEVICE list in the keil uvisin PACK INSTALLER. How do I import the device into the PCCK INSTALLER. DO I need to goto FILE -> IMPORT FROM FOLDER...  ?
What File or  file estension am I looking for in that folder?
I am not an experienced firmware developer, only an expert PCBA desinger who need to write some simple code to test&verify my hardware
KR
Øystein
6,509 次查看
oykr
OK, think I found why. I only have the MDK-LITE license
And on https://www2.keil.com/limits it states:
  • Arm7/Arm9/Cortex-R4 devices are not supported.
I guess thats why, unless there is a workaround
KR
Oystein
%3CLINGO-SUB%20id%3D%22lingo-sub-1963565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKEIL%E8%BD%AF%E4%BB%B6%E5%8C%85%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8FLPC2103%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1963565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%E3%80%82%E6%88%91%E6%9C%89%E4%B8%80%E5%9D%97%E6%97%A7%E7%94%B5%E8%B7%AF%E6%9D%BF%EF%BC%8C%E9%9C%80%E8%A6%81%E7%94%A8%E5%AE%83%E6%9D%A5%E5%86%99%20LPC2103%20%E7%9A%84%E4%BB%A3%E7%A0%81%E3%80%82Accoridn%20%E5%88%B0%20ARM%20KEIL%20uVISION%20%E6%94%AF%E6%8C%81%20LPC2103%20%3CA%20href%3D%22https%3A%2F%2Fwww.keil.com%2Fdd%2Fchip%2F3974.htm%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.keil.com%2Fdd%2Fchip%2F3974.htm%3C%2FA%3E%E4%BD%86%E6%88%91%E5%9C%A8%20PACK%20INSTALLER%20%E8%AE%BE%E5%A4%87%E5%88%97%E8%A1%A8%E4%B8%AD%E6%89%BE%E4%B8%8D%E5%88%B0%E5%AE%83%E3%80%82%E6%88%91%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E6%89%8B%E5%8A%A8%E6%B7%BB%E5%8A%A0%20LPC2103%20%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
