KEIL Software pack installer LPC2103
7,773件の閲覧回数
oykr
Hi. Have an old board that I need to write code for an LPC2103. Accoridn to ARM KEIL uVISION supports the LPC2103 https://www.keil.com/dd/chip/3974.htm but I cannot find it in the PACK INSTALLER device list. Do I manully need to add the LPC2103 software packs?
タグ(3)
7,743件の閲覧回数
Hello @oykr
Device family packs have only been created for Cortex-M based devices. For these older devices  the "legacy support" files need to be installed:
https://developer.arm.com/documentation/101407/0541/Creating-Applications/Tips-and-Tricks/Use-MDK-Ve...
Kind regards,
Alice
4 返答(返信)
7,753件の閲覧回数
Hello @oykr
I have already submitted the issue to ARM. I will send you with any updates. You can also ask arm if have any other issue with KEIL.
Alice
7,743件の閲覧回数
Hello @oykr
Kind regards,
Alice
6,965件の閲覧回数
oykr
I  downloaded and installed the leacy pack for
But I can still not see it in my DEVICE list in the keil uvisin PACK INSTALLER. How do I import the device into the PCCK INSTALLER. DO I need to goto FILE -> IMPORT FROM FOLDER...  ?
What File or  file estension am I looking for in that folder?
I am not an experienced firmware developer, only an expert PCBA desinger who need to write some simple code to test&verify my hardware
KR
Øystein
6,963件の閲覧回数
oykr
OK, think I found why. I only have the MDK-LITE license
And on https://www2.keil.com/limits it states:
  • Arm7/Arm9/Cortex-R4 devices are not supported.
I guess thats why, unless there is a workaround
KR
Oystein
%3CLINGO-SUB%20id%3D%22lingo-sub-1963565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKEIL%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%91%E3%83%83%E3%82%AF%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%A9%E3%83%BC%20LPC2103%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1963565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82LPC2103%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B8%E3%81%8F%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E5%8F%A4%E3%81%84%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82ARM%20KEIL%20uVISION%E3%81%AF%E3%80%81LPC2103%20%3CA%20href%3D%22https%3A%2F%2Fwww.keil.com%2Fdd%2Fchip%2F3974.htm%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.keil.com%2Fdd%2Fchip%2F3974.htm%3C%2FA%3E%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%26nbsp%3B%E3%81%97%E3%81%8B%E3%81%97%E3%80%81PACK%20INSTALLER%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82LPC2103%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%91%E3%83%83%E3%82%AF%E3%82%92%E6%89%8B%E9%96%93%E3%81%AA%E3%81%8F%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
