Implement DALI protocol using LPC11U68
zaidshaikh
How do i implement a dali protocol using LPC11U68 uc. I am new to DALI. Any help would be appreciated.
soledad
I suggest to check the AN11174 and AN11175 application notes that you can find in below threads:
DALI on LPC Microcontrollers
Sol
zaidshaikh
Thanks for your help. What i would do is order 1 master and 1 slave board and start with implementation. I would get back if am stuck.
