Bricked PN5190 via Secure Upgrade via NXP NFC Cockpit
ソリューションへジャンプ
7,910件の閲覧回数
Avis
I have NXP S32K144EVB-Q100 board and NXP NCx3321 S32K Addon Board3.Before the software was Firmware_2.05.
The problem I have is that when updating Secure Upgrade to PN5190Firmware_2.F7.esfwu, updated failed.
The board doesnt work anymore.
Log Monitor:
2024.04.05 13:00:05]:INFO:BoardDetect:Enforcing board selection for PN5190
2024.04.05 13:00:05]:INFO:ServiceFactory:Generating Services for VCOM_PN5190 @COM57
2024.04.05 13:00:06]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:07]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:08]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:09]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:11]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:11]:ERROR:ABalDelegate:Error while querying PIN_IRQ. GENERIC,USE_CONDITION
2024.04.05 13:00:11]:WARN:ABalDelegate:Waited for PIN_IRQ to go High. Timed out.
2024.04.05 13:00:12]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:12]:ERROR:ServiceFactory:InitHALPN5190.ApplyProtocolSettings failed. Status=240,IO_TIMEOUT
2024.04.05 13:00:12]:ERROR:ServiceFactory:InitHALPN5190() failed. Status=240,IO_TIMEOUT
2024.04.05 13:00:12]:ERROR:ServiceFactory:Previous FW Download to PN5190 seems to be incomplete. You may have to perform Secure FW Upgrade again
2024.04.05 13:00:12]:INFO:SecureFWUpgrade:Entering download mode
2024.04.05 13:00:13]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:14]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:15]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:16]:INFO:SecureFWUpgrade:Entered download mode
2024.04.05 13:00:17]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:18]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:19]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:19]:ERROR:ABalDelegate:Error while querying PIN_BUSY. GENERIC,USE_CONDITION
2024.04.05 13:00:19]:INFO:SecureFWUpgrade:Resetting Reader IC (FrontEnd) to enter normal mode
2024.04.05 13:00:20]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:21]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:22]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:22]:INFO:SecureFWUpgrade:Reader IC (FrontEnd) Reset complete.
2024.04.05 13:00:24]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:25]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:26]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:27]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:28]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:29]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:30]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:31]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:31]:INFO:ServiceFactory:Retrieved FW version from Secure Download Mode: 0.0
2024.04.05 13:00:31]:ERROR:ServiceFactory:GenerateServices (VCOM_PN5190 @COM57) Failed with 240,IO_TIMEOUT
2024.04.05 13:00:32]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:33]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:33]:INFO:ServiceFactory:uC FW Version: (Compiled on )
2024.04.05 13:00:34]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:35]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:36]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:37]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:38]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:39]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:39]:ERROR:ServiceFactory:Bal, Hal, OSal Initialization (VCOM_PN5190 @COM57) Failed with 240,IO_TIMEOUT
Thank you for taking the time to repair the board.
Avis
7,529件の閲覧回数
Avis
Hello, the problem is Fixed.
Avis
5 返答(返信)
7,530件の閲覧回数
Avis
Avis
7,554件の閲覧回数
Avis
Hello, @KaiLi
The EEPROM from the antena NFC is clear.
To solve this issue need be chip soldered.
NXP S32K144EVB-Q100 is working correct.
Avis
6,380件の閲覧回数
zhouwenlu
I am having the same problem as you, can I ask how to solder the chip. Can you share any specific instructions?
7,570件の閲覧回数
KaiLi
Hello @Avis
It's recommended that you log in https://www.docstore.nxp.com/
to download UM789513 and refer it to configurate your device.
Kelly
4,996件の閲覧回数
ctfy
my 5180 have same probrem ,and i can‘t download um789513 .do you have any other advice
%3CLINGO-SUB%20id%3D%22lingo-sub-1841260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENXP%20NFC%E3%82%B3%E3%83%83%E3%82%AF%E3%83%94%E3%83%83%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%AB%E3%82%88%E3%82%8BPN5190%E3%81%AE%E3%83%AC%E3%83%B3%E3%82%AC%E5%8C%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1841260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EHello%2C%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E7%A7%81%E3%81%AFNXP%20S32K144EVB-Q100%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8NXP%20NCx3321%20S32K%E3%82%A2%E3%83%89%E3%82%AA%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%993.%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AFFirmware_2.05%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E7%A7%81%E3%81%8C%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81Secure%20Upgrade%20%E3%82%92%20PN5190Firmware_2.F7.esfwu%20%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E6%9B%B4%E6%96%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%82%82%E3%81%86%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%83%AD%E3%82%B0%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%3A%3CBR%20%2F%3E2024.04.05%2013%3A00%3A05%5D%3AINFO%3ABoardDetect%3APN5190%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E9%81%B8%E6%8A%9E%E3%82%92%E5%BC%B7%E5%88%B6%E3%81%99%E3%82%8B%3CBR%20%2F%3E2024.04.05%2013%3A00%3A05%5D%3AINFO%3AServiceFactory%3AVCOM_PN5190%20%40COM57%E5%90%91%E3%81%91%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%AE%E7%94%9F%E6%88%90%3CBR%20%2F%3E2024.04.05%2013%3A00%3A06%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A07%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E2024.04.05%2013%3A00%3A08%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%86%85%E3%81%A7%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E2024.04.05%2013%3A00%3A09%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%86%85%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A11%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A11%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3AABalDelegate%3APIN_IRQ%E3%81%AE%E3%82%AF%E3%82%A8%E3%83%AA%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%B1%8E%E7%94%A8%E3%80%81USE_CONDITION%3CBR%20%2F%3E2024.04.05%2013%3A00%3A11%5D%3AWARN%3AABalDelegate%3APIN_IRQ%E3%81%8C%E9%AB%98%E3%81%8F%E3%81%AA%E3%82%8B%E3%81%AE%E3%82%92%E5%BE%85%E3%81%A1%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%80%82%3CBR%20%2F%3E2024.04.05%2013%3A00%3A12%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A12%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3AServiceFactory%3AInitHALPN5190.ApplyProtocolSettings%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3D240%2CIO_TIMEOUT%3CBR%20%2F%3E2024.04.05%2013%3A00%3A12%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3AServiceFactory%3AInitHALPN5190()%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3D240%2CIO_TIMEOUT%3CBR%20%2F%3E2024.04.05%2013%3A00%3A12%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3AServiceFactory%3APN5190%E3%81%B8%E3%81%AE%E4%BB%A5%E5%89%8D%E3%81%AEFW%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82Secure%20FW%20Upgrade%20%E3%82%92%E5%86%8D%E5%BA%A6%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E2024.04.05%2013%3A00%3A12%5D%3AINFO%3ASecureFWUpgrade%3A%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E2024.04.05%2013%3A00%3A13%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E2024.04.05%2013%3A00%3A14%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A15%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A16%5D%3AINFO%3ASecureFWUpgrade%3A%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E2024.04.05%2013%3A00%3A17%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A18%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A19%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%86%85%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A19%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3AABalDelegate%3APIN_BUSY%E3%81%AE%E3%82%AF%E3%82%A8%E3%83%AA%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%B1%8E%E7%94%A8%E3%80%81USE_CONDITION%3CBR%20%2F%3E2024.04.05%2013%3A00%3A19%5D%3A%E6%83%85%E5%A0%B1%3ASecureFWUpgrade%3A%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BCIC(%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89)%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%A6%E9%80%9A%E5%B8%B8%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%BE%E3%81%99%3CBR%20%2F%3E2024.04.05%2013%3A00%3A20%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E2024.04.05%2013%3A00%3A21%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A22%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A22%5D%3AINFO%3ASecureFWUpgrade%3A%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BCIC(%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89)%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E2024.04.05%2013%3A00%3A24%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A25%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A26%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A27%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A28%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A29%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E2024.04.05%2013%3A00%3A30%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%22%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%22%3CBR%20%2F%3E2024.04.05%2013%3A00%3A31%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E2024.04.05%2013%3A00%3A31%5D%3AINFO%3AServiceFactory%3A%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9FFW%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A0.0%3CBR%20%2F%3E2024.04.05%2013%3A00%3A31%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3AServiceFactory%3AGenerateServices%EF%BC%88VCOM_PN5190%20%40COM57)%E3%81%8C240%2CIO_TIMEOUT%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E2024.04.05%2013%3A00%3A32%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E2024.04.05%2013%3A00%3A33%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A33%5D%3AINFO%3AServiceFactory%3AuC%20FW%20Version%3A%20(%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%97%A5)%3CBR%20%2F%3E2024.04.05%2013%3A00%3A34%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%20%E5%88%B6%3CBR%20%2F%3E2024.04.05%2013%3A00%3A35%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A36%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E2024.04.05%2013%3A00%3A37%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E2024.04.05%2013%3A00%3A38%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A39%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%3CBR%20%2F%3E2024.04.05%2013%3A00%3A39%5D%3A%E3%82%A8%E3%83%A9%E3%83%BC%3AServiceFactory%3ABal%E3%80%81Hal%E3%80%81OSal%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96(VCOM_PN5190%20%40COM57)%E3%81%8C240%2CIO_TIMEOUT%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22port.png%22%20style%3D%22width%3A%20483px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22port.png%22%20style%3D%22width%3A%20483px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F272189i993D49BB36160519%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22port.png%22%20alt%3D%22port.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E4%BF%AE%E7%90%86%E3%81%AB%E3%81%8A%E6%99%82%E9%96%93%E3%82%92%E5%89%B2%E3%81%84%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%3CBR%20%2F%3E%3C%2FSPAN%3E%E3%82%A8%E3%82%A4%E3%83%93%E3%82%B9%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2055910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%86%8D%3ANXP%20NFC%E3%82%B3%E3%83%83%E3%82%AF%E3%83%94%E3%83%83%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%AB%E3%82%88%E3%82%8BPN5190%E3%81%AE%E3%83%AC%E3%83%B3%E3%82%AC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2055910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A7%81%E3%81%AE5180%E3%81%AF%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81UM789513%20.do%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E4%BB%96%E3%81%AB%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2008829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%86%8D%3ANXP%20NFC%E3%82%B3%E3%83%83%E3%82%AF%E3%83%94%E3%83%83%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%AB%E3%82%88%E3%82%8BPN5190%E3%81%AE%E3%83%AC%E3%83%B3%E3%82%AC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2008829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%82%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%A8%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E6%96%B9%E6%B3%95%E3%82%92%E5%B0%8B%E3%81%AD%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AA%E6%8C%87%E7%A4%BA%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1843934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%86%8D%3ANXP%20NFC%E3%82%B3%E3%83%83%E3%82%AF%E3%83%94%E3%83%83%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%AB%E3%82%88%E3%82%8BPN5190%E3%81%AE%E3%83%AC%E3%83%B3%E3%82%AC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1843934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E4%BF%AE%E6%AD%A3%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EBR%E3%81%AE%3CBR%20%2F%3E%E3%82%A8%E3%82%A4%E3%83%93%E3%82%B9%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1843021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%86%8D%3ANXP%20NFC%E3%82%B3%E3%83%83%E3%82%AF%E3%83%94%E3%83%83%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%AB%E3%82%88%E3%82%8BPN5190%E3%81%AE%E3%83%AC%E3%83%B3%E3%82%AC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1843021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205266%22%20target%3D%22_blank%22%3E%40KaiLi%3C%2FA%3E%3CBR%20%2F%3Eantena%20NFC%E3%81%AEEEPROM%E3%81%AF%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%81%E3%83%83%E3%83%97%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ENXP%20S32K144EVB-Q100%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EBR%E3%81%AE%3CBR%20%2F%3E%E3%82%A8%E3%82%A4%E3%83%93%E3%82%B9%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842313%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%86%8D%3ANXP%20NFC%E3%82%B3%E3%83%83%E3%82%AF%E3%83%94%E3%83%83%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%AB%E3%82%88%E3%82%8BPN5190%E3%81%AE%E3%83%AC%E3%83%B3%E3%82%AC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842313%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231879%22%20target%3D%22_blank%22%3E%40Avis%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.docstore.nxp.com%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.docstore.nxp.com%2F%3C%2FA%3E%20%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3EUM789513%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E5%8F%82%E7%85%A7%E3%81%97%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22KellyLi_0-1712568600400.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KellyLi_0-1712568600400.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F272484iA57D4048F8A0B78C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22KellyLi_0-1712568600400.png%22%20alt%3D%22KellyLi_0-1712568600400.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B1%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E
