Bricked PN5190 via Secure Upgrade via NXP NFC Cockpit
7,886 次查看
Avis
I have NXP S32K144EVB-Q100 board and NXP NCx3321 S32K Addon Board3.Before the software was Firmware_2.05.
The problem I have is that when updating Secure Upgrade to PN5190Firmware_2.F7.esfwu, updated failed.
The board doesnt work anymore.
Log Monitor:
2024.04.05 13:00:05]:INFO:BoardDetect:Enforcing board selection for PN5190
2024.04.05 13:00:05]:INFO:ServiceFactory:Generating Services for VCOM_PN5190 @COM57
2024.04.05 13:00:06]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:07]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:08]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:09]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:11]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:11]:ERROR:ABalDelegate:Error while querying PIN_IRQ. GENERIC,USE_CONDITION
2024.04.05 13:00:11]:WARN:ABalDelegate:Waited for PIN_IRQ to go High. Timed out.
2024.04.05 13:00:12]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:12]:ERROR:ServiceFactory:InitHALPN5190.ApplyProtocolSettings failed. Status=240,IO_TIMEOUT
2024.04.05 13:00:12]:ERROR:ServiceFactory:InitHALPN5190() failed. Status=240,IO_TIMEOUT
2024.04.05 13:00:12]:ERROR:ServiceFactory:Previous FW Download to PN5190 seems to be incomplete. You may have to perform Secure FW Upgrade again
2024.04.05 13:00:12]:INFO:SecureFWUpgrade:Entering download mode
2024.04.05 13:00:13]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:14]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:15]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:16]:INFO:SecureFWUpgrade:Entered download mode
2024.04.05 13:00:17]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:18]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:19]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:19]:ERROR:ABalDelegate:Error while querying PIN_BUSY. GENERIC,USE_CONDITION
2024.04.05 13:00:19]:INFO:SecureFWUpgrade:Resetting Reader IC (FrontEnd) to enter normal mode
2024.04.05 13:00:20]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:21]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:22]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:22]:INFO:SecureFWUpgrade:Reader IC (FrontEnd) Reset complete.
2024.04.05 13:00:24]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:25]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:26]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:27]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:28]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:29]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:30]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:31]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:31]:INFO:ServiceFactory:Retrieved FW version from Secure Download Mode: 0.0
2024.04.05 13:00:31]:ERROR:ServiceFactory:GenerateServices (VCOM_PN5190 @COM57) Failed with 240,IO_TIMEOUT
2024.04.05 13:00:32]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:33]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:33]:INFO:ServiceFactory:uC FW Version: (Compiled on )
2024.04.05 13:00:34]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:35]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:36]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:37]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:38]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:39]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:39]:ERROR:ServiceFactory:Bal, Hal, OSal Initialization (VCOM_PN5190 @COM57) Failed with 240,IO_TIMEOUT
Thank you for taking the time to repair the board.
Avis
7,505 次查看
Avis
Hello, the problem is Fixed.
Avis
5 回复数
7,506 次查看
Avis
Avis
7,530 次查看
Avis
Hello, @KaiLi
The EEPROM from the antena NFC is clear.
To solve this issue need be chip soldered.
NXP S32K144EVB-Q100 is working correct.
Avis
6,356 次查看
zhouwenlu
I am having the same problem as you, can I ask how to solder the chip. Can you share any specific instructions?
7,546 次查看
KaiLi
Hello @Avis
It's recommended that you log in https://www.docstore.nxp.com/
to download UM789513 and refer it to configurate your device.
Kelly
4,972 次查看
ctfy
my 5180 have same probrem ,and i can‘t download um789513 .do you have any other advice
%3CLINGO-SUB%20id%3D%22lingo-sub-1841260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%80%9A%E8%BF%87%20NXP%20NFC%20Cockpit%20%E8%BF%9B%E8%A1%8C%E5%AE%89%E5%85%A8%E5%8D%87%E7%BA%A7%EF%BC%8C%E6%8D%9F%E5%9D%8F%20PN5190%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1841260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EHello%2C%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E6%9C%89%20NXP%20S32K144EVB-Q100%20%E4%B8%BB%E6%9D%BF%E5%92%8C%20NXP%20NCx3321%20S32K%20Addon%20Board3%E3%80%82%E4%B9%8B%E5%89%8D%E7%9A%84%E8%BD%AF%E4%BB%B6%E6%98%AF%20Firmware_2.05%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E9%81%87%E5%88%B0%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E5%BD%93%E5%B0%86%E5%AE%89%E5%85%A8%E5%8D%87%E7%BA%A7%E6%9B%B4%E6%96%B0%E5%88%B0%20PN5190Firmware_2.F7.esfwu%20%E6%97%B6%EF%BC%8C%E6%9B%B4%E6%96%B0%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E8%AF%A5%E6%9D%BF%E4%B8%8D%E5%86%8D%E5%B7%A5%E4%BD%9C%E4%BA%86%E3%80%82%3CBR%20%2F%3E%E6%97%A5%E5%BF%97%E7%9B%91%E6%8E%A7%EF%BC%9A%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A05%5D%3AINFO%3ABoardDetect%3A%E5%BC%BA%E5%88%B6%E6%89%A7%E8%A1%8C%20PN5190%20%E7%9A%84%E4%B8%BB%E6%9D%BF%E9%80%89%E6%8B%A9%3CBR%20%2F%3E2024.04.05%2013%3A00%3A05%5D%3AINFO%3AServiceFactory%3A%E4%B8%BA%20VCOM_PN5190%20%40COM57%20%E7%94%9F%E6%88%90%E6%9C%8D%E5%8A%A1%3CBR%20%2F%3E2024.04.05%2013%3A00%3A06%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A07%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A08%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A09%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A11%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A11%5D%3AERROR%3AABalDelegate%EF%BC%9A%E6%9F%A5%E8%AF%A2%20PIN_IRQ%20%E6%97%B6%E5%87%BA%E9%94%99%E3%80%82%E9%80%9A%E7%94%A8%E4%BD%BF%E7%94%A8%E6%9D%A1%E4%BB%B6%3CBR%20%2F%3E2024.04.05%2013%3A00%3A11%5D%3AWARN%3AABalDelegate%3A%E7%AD%89%E5%BE%85%20PIN_IRQ%20%E5%8F%98%E4%B8%BA%E9%AB%98%E7%94%B5%E5%B9%B3%E3%80%82%E8%B6%85%E6%97%B6%E3%80%82%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A12%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A12%5D%3A%E9%94%99%E8%AF%AF%EF%BC%9AServiceFactory%EF%BC%9AInitHALPN5190.ApplyProtocolSettings%20%E5%A4%B1%E8%B4%A5%E3%80%82%E7%8A%B6%E6%80%81%3D240%EF%BC%8CIO_TIMEOUT%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A12%5D%3A%E9%94%99%E8%AF%AF%EF%BC%9AServiceFactory%EF%BC%9AInitHALPN5190()%20%E5%A4%B1%E8%B4%A5%E3%80%82%E7%8A%B6%E6%80%81%3D240%EF%BC%8CIO_TIMEOUT%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A12%5D%3AERROR%3AServiceFactory%3APrevious%20FW%20%E4%B8%8B%E8%BD%BD%E8%87%B3%20PN5190%20%E4%BC%BC%E4%B9%8E%E4%B8%8D%E5%AE%8C%E6%95%B4%E3%80%82%E6%82%A8%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E5%86%8D%E6%AC%A1%E6%89%A7%E8%A1%8C%E5%AE%89%E5%85%A8%E5%9B%BA%E4%BB%B6%E5%8D%87%E7%BA%A7%3CBR%20%2F%3E2024.04.05%2013%3A00%3A12%5D%3AINFO%3ASecureFWUpgrade%3A%E8%BF%9B%E5%85%A5%E4%B8%8B%E8%BD%BD%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E2024.04.05%2013%3A00%3A13%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A14%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A15%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A16%5D%3AINFO%3ASecureFWUpgrade%3A%E8%BF%9B%E5%85%A5%E4%B8%8B%E8%BD%BD%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E2024.04.05%2013%3A00%3A17%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A18%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A19%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A19%5D%3AERROR%3AABalDelegate%3A%E6%9F%A5%E8%AF%A2PIN_BUSY%E6%97%B6%E5%87%BA%E9%94%99%E3%80%82%E9%80%9A%E7%94%A8%E4%BD%BF%E7%94%A8%E6%9D%A1%E4%BB%B6%3CBR%20%2F%3E2024.04.05%2013%3A00%3A19%5D%3AINFO%3ASecureFWUpgrade%3A%E9%87%8D%E7%BD%AE%E8%AF%BB%E5%8D%A1%E5%99%A8%20IC%EF%BC%88%E5%89%8D%E7%AB%AF%EF%BC%89%E4%BB%A5%E8%BF%9B%E5%85%A5%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E2024.04.05%2013%3A00%3A20%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A21%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A22%5D%3AERROR%3AApp%3A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A22%5D%3AINFO%3ASecureFWUpgrade%3A%E8%AF%BB%E5%8F%96%E5%99%A8%20IC%EF%BC%88%E5%89%8D%E7%AB%AF%EF%BC%89%E9%87%8D%E7%BD%AE%E5%AE%8C%E6%88%90%E3%80%82%3CBR%20%2F%3E2024.04.05%2013%3A00%3A24%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A25%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A26%5D%3AERROR%3AApp%3A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A27%5D%3AERROR%3AApp%3A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A28%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A29%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A30%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A31%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A31%5D%3AINFO%3AServiceFactory%3A%E4%BB%8E%E5%AE%89%E5%85%A8%E4%B8%8B%E8%BD%BD%E6%A8%A1%E5%BC%8F%E6%A3%80%E7%B4%A2%E5%88%B0%E7%9A%84%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9A0.0%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A31%5D%3AERROR%3AServiceFactory%3AGenerateServices%20(VCOM_PN5190%20%40COM57)%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%20240%2CIO_TIMEOUT%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A32%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A33%5D%3AERROR%3AApp%3A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A33%5D%3AINFO%3AServiceFactory%3AuC%20FW%20%E7%89%88%E6%9C%AC%3A%20(%E7%BC%96%E8%AF%91%E4%BA%8E)%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A34%5D%3AERROR%3AApp%3A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A35%5D%3AERROR%3AApp%3A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A36%5D%3AERROR%3AApp%3A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A37%5D%3AERROR%3AApp%3A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A38%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A39%5D%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%91%E7%94%9F%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%E2%80%9C%E6%93%8D%E4%BD%9C%E5%B7%B2%E8%B6%85%E6%97%B6%E3%80%82%E2%80%9D%3CBR%20%2F%3E%202024.04.05%2013%3A00%3A39%5D%3A%E9%94%99%E8%AF%AF%EF%BC%9AServiceFactory%EF%BC%9ABal%E3%80%81Hal%E3%80%81OSal%20%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%88VCOM_PN5190%20%40COM57%EF%BC%89%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%20240%EF%BC%8CIO_TIMEOUT%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22port.png%22%20style%3D%22width%3A%20483px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22port.png%22%20style%3D%22width%3A%20483px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F272189i993D49BB36160519%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22port.png%22%20alt%3D%22port.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8A%BD%E5%87%BA%E6%97%B6%E9%97%B4%E6%9D%A5%E4%BF%AE%E5%A4%8D%E7%94%B5%E8%B7%AF%E6%9D%BF%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E9%97%AE%E5%80%99%3CBR%20%2F%3E%3C%2FSPAN%3E%E5%AE%89%E9%A3%9E%E5%A3%AB%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2055910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%20NXP%20NFC%20Cockpit%20%E8%BF%9B%E8%A1%8C%E5%AE%89%E5%85%A8%E5%8D%87%E7%BA%A7%EF%BC%8C%E5%AF%BC%E8%87%B4%20PN5190%20%E5%8F%98%E7%A0%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2055910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E7%9A%84%205180%20%E4%B9%9F%E6%9C%89%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%80%8C%E4%B8%94%E6%88%91%E6%97%A0%E6%B3%95%E4%B8%8B%E8%BD%BD%20um789513.do%E4%BD%A0%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E5%BB%BA%E8%AE%AE%E5%90%97%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2008829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%20NXP%20NFC%20Cockpit%20%E8%BF%9B%E8%A1%8C%E5%AE%89%E5%85%A8%E5%8D%87%E7%BA%A7%EF%BC%8C%E5%AF%BC%E8%87%B4%20PN5190%20%E5%8F%98%E7%A0%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2008829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E5%92%8C%E4%BD%A0%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E9%97%AE%E5%A6%82%E4%BD%95%E7%84%8A%E6%8E%A5%E8%8A%AF%E7%89%87%E3%80%82%E6%82%A8%E8%83%BD%E5%88%86%E4%BA%AB%E4%B8%80%E4%BA%9B%E5%85%B7%E4%BD%93%E7%9A%84%E8%AF%B4%E6%98%8E%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1843934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%20NXP%20NFC%20Cockpit%20%E8%BF%9B%E8%A1%8C%E5%AE%89%E5%85%A8%E5%8D%87%E7%BA%A7%EF%BC%8C%E5%AF%BC%E8%87%B4%20PN5190%20%E5%8F%98%E7%A0%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1843934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E9%97%AE%E9%A2%98%E5%B7%B2%E8%A7%A3%E5%86%B3%E3%80%82%3CBR%20%2F%3EBR%3CBR%20%2F%3E%E5%AE%89%E9%A3%9E%E5%A3%AB%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1843021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%20NXP%20NFC%20Cockpit%20%E8%BF%9B%E8%A1%8C%E5%AE%89%E5%85%A8%E5%8D%87%E7%BA%A7%EF%BC%8C%E5%AF%BC%E8%87%B4%20PN5190%20%E5%8F%98%E7%A0%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1843021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205266%22%20target%3D%22_blank%22%3E%40KaiLi%3C%2FA%3E%3CBR%20%2F%3E%E5%A4%A9%E7%BA%BF%20NFC%20%E7%9A%84%20EEPROM%20%E6%98%AF%E6%B8%85%E6%99%B0%E7%9A%84%E3%80%82%3CBR%20%2F%3E%E8%A6%81%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E9%9C%80%E8%A6%81%E5%AF%B9%E8%8A%AF%E7%89%87%E8%BF%9B%E8%A1%8C%E7%84%8A%E6%8E%A5%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ENXP%20S32K144EVB-Q100%20%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%E3%80%82%3CBR%20%2F%3E%20BR%3CBR%20%2F%3E%E5%AE%89%E9%A3%9E%E5%A3%AB%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842313%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%20NXP%20NFC%20Cockpit%20%E8%BF%9B%E8%A1%8C%E5%AE%89%E5%85%A8%E5%8D%87%E7%BA%A7%EF%BC%8C%E5%AF%BC%E8%87%B4%20PN5190%20%E5%8F%98%E7%A0%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842313%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231879%22%20target%3D%22_blank%22%3E%40Avis%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E5%BB%BA%E8%AE%AE%E6%82%A8%E7%99%BB%E5%BD%95%3CA%20href%3D%22https%3A%2F%2Fwww.docstore.nxp.com%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.docstore.nxp.com%2F%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E4%B8%8B%E8%BD%BD%20UM789513%20%E5%B9%B6%E5%8F%82%E8%80%83%E5%AE%83%E6%9D%A5%E9%85%8D%E7%BD%AE%E6%82%A8%E7%9A%84%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22KellyLi_0-1712568600400.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KellyLi_0-1712568600400.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F272484iA57D4048F8A0B78C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22KellyLi_0-1712568600400.png%22%20alt%3D%22KellyLi_0-1712568600400.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%87%AF%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E
