Bricked PN5190 via Secure Upgrade via NXP NFC Cockpit
Avis
I have NXP S32K144EVB-Q100 board and NXP NCx3321 S32K Addon Board3.Before the software was Firmware_2.05.
The problem I have is that when updating Secure Upgrade to PN5190Firmware_2.F7.esfwu, updated failed.
The board doesnt work anymore.
Log Monitor:
2024.04.05 13:00:05]:INFO:BoardDetect:Enforcing board selection for PN5190
2024.04.05 13:00:05]:INFO:ServiceFactory:Generating Services for VCOM_PN5190 @COM57
2024.04.05 13:00:06]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:07]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:08]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:09]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:11]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:11]:ERROR:ABalDelegate:Error while querying PIN_IRQ. GENERIC,USE_CONDITION
2024.04.05 13:00:11]:WARN:ABalDelegate:Waited for PIN_IRQ to go High. Timed out.
2024.04.05 13:00:12]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:12]:ERROR:ServiceFactory:InitHALPN5190.ApplyProtocolSettings failed. Status=240,IO_TIMEOUT
2024.04.05 13:00:12]:ERROR:ServiceFactory:InitHALPN5190() failed. Status=240,IO_TIMEOUT
2024.04.05 13:00:12]:ERROR:ServiceFactory:Previous FW Download to PN5190 seems to be incomplete. You may have to perform Secure FW Upgrade again
2024.04.05 13:00:12]:INFO:SecureFWUpgrade:Entering download mode
2024.04.05 13:00:13]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:14]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:15]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:16]:INFO:SecureFWUpgrade:Entered download mode
2024.04.05 13:00:17]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:18]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:19]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:19]:ERROR:ABalDelegate:Error while querying PIN_BUSY. GENERIC,USE_CONDITION
2024.04.05 13:00:19]:INFO:SecureFWUpgrade:Resetting Reader IC (FrontEnd) to enter normal mode
2024.04.05 13:00:20]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:21]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:22]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:22]:INFO:SecureFWUpgrade:Reader IC (FrontEnd) Reset complete.
2024.04.05 13:00:24]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:25]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:26]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:27]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:28]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:29]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:30]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:31]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:31]:INFO:ServiceFactory:Retrieved FW version from Secure Download Mode: 0.0
2024.04.05 13:00:31]:ERROR:ServiceFactory:GenerateServices (VCOM_PN5190 @COM57) Failed with 240,IO_TIMEOUT
2024.04.05 13:00:32]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:33]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:33]:INFO:ServiceFactory:uC FW Version: (Compiled on )
2024.04.05 13:00:34]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:35]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:36]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:37]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:38]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:39]:ERROR:App:Internal Error occurred "The operation has timed out." in System
2024.04.05 13:00:39]:ERROR:ServiceFactory:Bal, Hal, OSal Initialization (VCOM_PN5190 @COM57) Failed with 240,IO_TIMEOUT
Thank you for taking the time to repair the board.
Avis
Avis
Hello, the problem is Fixed.
Avis
Avis
Avis
Avis
Hello, @KaiLi
The EEPROM from the antena NFC is clear.
To solve this issue need be chip soldered.
NXP S32K144EVB-Q100 is working correct.
Avis
zhouwenlu
I am having the same problem as you, can I ask how to solder the chip. Can you share any specific instructions?
KaiLi
Hello @Avis
It's recommended that you log in https://www.docstore.nxp.com/
to download UM789513 and refer it to configurate your device.
Kelly
ctfy
my 5180 have same probrem ,and i can‘t download um789513 .do you have any other advice
%3CLINGO-SUB%20id%3D%22lingo-sub-1841260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBricked%20PN5190%20via%20Secure%20Upgrade%20via%20NXP%20NFC%20Cockpit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1841260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EHello%2C%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EI%20have%26nbsp%3BNXP%20S32K144EVB-Q100%20board%20and%20NXP%20NCx3321%20S32K%20Addon%20Board3.Before%20the%20software%20was%26nbsp%3BFirmware_2.05.%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EThe%20problem%20I%20have%20is%20that%20when%20updating%20Secure%20Upgrade%20to%20PN5190Firmware_2.F7.esfwu%2C%20updated%20failed.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EThe%20board%20doesnt%20work%20anymore.%3CBR%20%2F%3ELog%20Monitor%3A%3CBR%20%2F%3E2024.04.05%2013%3A00%3A05%5D%3AINFO%3ABoardDetect%3AEnforcing%20board%20selection%20for%20PN5190%3CBR%20%2F%3E2024.04.05%2013%3A00%3A05%5D%3AINFO%3AServiceFactory%3AGenerating%20Services%20for%20VCOM_PN5190%20%40COM57%3CBR%20%2F%3E2024.04.05%2013%3A00%3A06%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A07%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A08%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A09%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A11%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A11%5D%3AERROR%3AABalDelegate%3AError%20while%20querying%20PIN_IRQ.%20GENERIC%2CUSE_CONDITION%3CBR%20%2F%3E2024.04.05%2013%3A00%3A11%5D%3AWARN%3AABalDelegate%3AWaited%20for%20PIN_IRQ%20to%20go%20High.%20Timed%20out.%3CBR%20%2F%3E2024.04.05%2013%3A00%3A12%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A12%5D%3AERROR%3AServiceFactory%3AInitHALPN5190.ApplyProtocolSettings%20failed.%20Status%3D240%2CIO_TIMEOUT%3CBR%20%2F%3E2024.04.05%2013%3A00%3A12%5D%3AERROR%3AServiceFactory%3AInitHALPN5190()%20failed.%20Status%3D240%2CIO_TIMEOUT%3CBR%20%2F%3E2024.04.05%2013%3A00%3A12%5D%3AERROR%3AServiceFactory%3APrevious%20FW%20Download%20to%20PN5190%20seems%20to%20be%20incomplete.%20You%20may%20have%20to%20perform%20Secure%20FW%20Upgrade%20again%3CBR%20%2F%3E2024.04.05%2013%3A00%3A12%5D%3AINFO%3ASecureFWUpgrade%3AEntering%20download%20mode%3CBR%20%2F%3E2024.04.05%2013%3A00%3A13%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A14%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A15%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A16%5D%3AINFO%3ASecureFWUpgrade%3AEntered%20download%20mode%3CBR%20%2F%3E2024.04.05%2013%3A00%3A17%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A18%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A19%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A19%5D%3AERROR%3AABalDelegate%3AError%20while%20querying%20PIN_BUSY.%20GENERIC%2CUSE_CONDITION%3CBR%20%2F%3E2024.04.05%2013%3A00%3A19%5D%3AINFO%3ASecureFWUpgrade%3AResetting%20Reader%20IC%20(FrontEnd)%20to%20enter%20normal%20mode%3CBR%20%2F%3E2024.04.05%2013%3A00%3A20%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A21%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A22%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A22%5D%3AINFO%3ASecureFWUpgrade%3AReader%20IC%20(FrontEnd)%20Reset%20complete.%3CBR%20%2F%3E2024.04.05%2013%3A00%3A24%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A25%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A26%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A27%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A28%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A29%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A30%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A31%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A31%5D%3AINFO%3AServiceFactory%3ARetrieved%20FW%20version%20from%20Secure%20Download%20Mode%3A%200.0%3CBR%20%2F%3E2024.04.05%2013%3A00%3A31%5D%3AERROR%3AServiceFactory%3AGenerateServices%20(VCOM_PN5190%20%40COM57)%20Failed%20with%20240%2CIO_TIMEOUT%3CBR%20%2F%3E2024.04.05%2013%3A00%3A32%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A33%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A33%5D%3AINFO%3AServiceFactory%3AuC%20FW%20Version%3A%20(Compiled%20on%20)%3CBR%20%2F%3E2024.04.05%2013%3A00%3A34%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A35%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A36%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A37%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A38%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A39%5D%3AERROR%3AApp%3AInternal%20Error%20occurred%20%22The%20operation%20has%20timed%20out.%22%20in%20System%3CBR%20%2F%3E2024.04.05%2013%3A00%3A39%5D%3AERROR%3AServiceFactory%3ABal%2C%20Hal%2C%20OSal%20Initialization%20(VCOM_PN5190%20%40COM57)%20Failed%20with%20240%2CIO_TIMEOUT%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22port.png%22%20style%3D%22width%3A%20483px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22port.png%22%20style%3D%22width%3A%20483px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F272189i993D49BB36160519%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22port.png%22%20alt%3D%22port.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EThank%20you%20for%20taking%20the%20time%20to%20repair%20the%20board.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ERegards%3CBR%20%2F%3E%3C%2FSPAN%3EAvis%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2055910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Bricked%20PN5190%20via%20Secure%20Upgrade%20via%20NXP%20NFC%20Cockpit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2055910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Emy%205180%20have%20same%20probrem%20%EF%BC%8Cand%20i%20can%E2%80%98t%20download%20um789513%20.do%20you%20have%20any%20other%20advice%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2008829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Bricked%20PN5190%20via%20Secure%20Upgrade%20via%20NXP%20NFC%20Cockpit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2008829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20having%20the%20same%20problem%20as%20you%2C%20can%20I%20ask%20how%20to%20solder%20the%20chip.%20Can%20you%20share%20any%20specific%20instructions%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1843934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Bricked%20PN5190%20via%20Secure%20Upgrade%20via%20NXP%20NFC%20Cockpit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1843934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHello%2C%20the%20problem%20is%20Fixed.%3CBR%20%2F%3EBR%3CBR%20%2F%3EAvis%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1843021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Bricked%20PN5190%20via%20Secure%20Upgrade%20via%20NXP%20NFC%20Cockpit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1843021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205266%22%20target%3D%22_blank%22%3E%40KaiLi%3C%2FA%3E%3CBR%20%2F%3EThe%20EEPROM%20from%20the%20antena%20NFC%20is%20clear.%3CBR%20%2F%3ETo%20solve%20this%20issue%20need%20be%20chip%20soldered.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ENXP%20S32K144EVB-Q100%26nbsp%3Bis%20working%20correct.%3CBR%20%2F%3EBR%3CBR%20%2F%3EAvis%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842313%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Bricked%20PN5190%20via%20Secure%20Upgrade%20via%20NXP%20NFC%20Cockpit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842313%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231879%22%20target%3D%22_blank%22%3E%40Avis%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EIt's%20recommended%20that%20you%20log%20in%20%3CA%20href%3D%22https%3A%2F%2Fwww.docstore.nxp.com%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.docstore.nxp.com%2F%3C%2FA%3E%3C%2FP%3E%0A%3CP%3Eto%20download%20UM789513%20and%20refer%20it%20to%20configurate%20your%20device.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22KellyLi_0-1712568600400.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KellyLi_0-1712568600400.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F272484iA57D4048F8A0B78C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22KellyLi_0-1712568600400.png%22%20alt%3D%22KellyLi_0-1712568600400.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EKelly%3C%2FP%3E%3C%2FLINGO-BODY%3E
