interrupt with PEx and SDK
1,345 次查看
danielecortella
how to use the interrupt with fls_gpio?
I want to use this pin as interrupt so i put :
but i have this error
and i can't select any device. Why? There is an example?
Daniele
1,212 次查看
ivadorazinova
Hello Daniele,
you forget to say important details as
  • what MCU are you using?
  • do you use KDS? which version?
  • which KSDK version?
This can be caused by reserved pin.
I created the example for you, it is for FRDM-K64F with component fsl_gpio with the SW2 interrupt.
Maybe it can help you, maybe not.
Please, let me know.
Iva
1,212 次查看
danielecortella
i'm using the kl46 with KDS3.0 and KSDK 1.2.
Thanks for the sample, i watch where i'm wrong.
