TWR-K21F120MA
TWR-K21F120MA
1,807 次查看
vikashkumar
I have TWR-K21F120MA board , i want to run usb example code on this board , please guide me how can i achieve it.
I'm using kinetis IDE.
Thank you
1,715 次查看
MarekTrmac
Hi Vikash,
go to http://mcuxpresso.nxp.com/, create configuration for TWR-K21F120MA for KDS toolchain; generate SDK package in SDK builder and download the package and unzip. USB stack middleware is included by default.
Start KDS 3.2. Import example project using File - Import - General - Existing project into workspace
As root directory select "boards\twr21f120m\usb_examples\".
Ensure "Copy projects into workspace" is NOT selected.
Click Next and select any of the USB example projects.
Build, Run and customize the example project.
Marek
1,715 次查看
vikashkumar
Hi Marek,
Thank you for response.
Actually i have example of demo application and i'm using ucosii so i select this path (examples\twrk21f120m\demo_apps\usb\host\msd\msd_cmd\ucosii\kds). But in read me doc file the path is <install_dir>/usb/usb_core/host/lib/ucosii/<tool_chain>/<soc_name>.
So i want to conform it , i need to add tool_chain file?
