Installing KSDK on Ubuntu 64-bit
1,300 次查看
midnight
Is there a procedure for getting the KSDK installed on Ubuntu 17.04 and all the other files needed for developing for the TWR-K65F180M?
K-
1,190 次查看
jorge_a_vazquez
Hi Kyle Unice
I hear from a colleague that you problem has been resolved in a case. The problem seams to be related with your tower serial connections and power supply, can you confirm that you problem has been resolved?
If the problem still exists could you explain more your issue? as you can see in the image below, you can download KSDK for linux:
Jorge Alcala
