Use the TWR-KW24D512's USB CDC virtual port function include in zigbee pro stack can not receive data send form PC, The KW24 was used as device
1,134 次查看
stiuostonbrigth
Use  the TWR-KW24D512's USB CDC virtual port  function include in zigbee pro stack can not receive data send form PC, The KW24 was used as device.
1,043 次查看
stephanie_m
Currently the available devices with ZigBee support are the JN516x family.
The currently supported stacks by KW24D are: Thread, 802.15.4 MAC and SMAC.
ZigBee 3.0 will be supported in KW41Z in Q1 2018 and currently there are no plans to support this stack in KW24D.
Sorry for the inconvenience that this might cause you.
Estephania
