I am trying to flash a mk20dx128vlf5 with OpenOCD 9.0 rc1and a Jlink.
I'm struggling to get a good debugging setup. I have the following as my openocd.cfg:
source [find interface/jlink.cfg]
# Freescale Kinetis K20 device. Should be compatible with K40,
# just set a custom name.
set CHIPNAME k20
source [find target/k40.cfg]
adapter_khz 1000
reset_config srst_only
# Scratch RAM for verify
# XXX: This verify method is broken due to a problem with reset?
k20.cpu configure -work-area-phys 0x1FFFE000 -work-area-size 16384
# One 128K flash bank
flash bank pflash.0 kinetis 0x00000000 0x20000 0 4 $_TARGETNAME
Trying to flash with `/usr/local/bin/openocd -f ./openocd.cfg -c "program app-image.hex reset"`
results in /openocd.cfg:29: Error: invalid command name "k20.cpu"
Doe anyone know how to fix this issue or have another solution for flashing this mcu from Linux?
Thanks!
