@Jmir
I think the short answer is "No".
We had a discussion regarding ths a couple of months or so about it and there are a lot of reasons why direct DO is limited to 100s if kHz when you want to do something intelligent. If it's a repeating signal, there are tricks like using the SPI ports that will give you speeds up to 10Mbps or so.
What are you trying to do?
myke
