RS232 serial communication with an external device(My case:Programmable DC Electronic Load)
2,703 次查看
kirantujare
I want to establish a serial communication between TWR SER with an external device(BK Precision's Programmable DC Electronic Load). I plan on using the AsynchroSerial feature on processor expert. I want to know if this approach is correct and I'm open to suggestions. Also, if there are example projects on this feature in KDS or CodeWarrior?
2,244 次查看
Robin_Shen
Hi Kiran,
Please refer the Typical Usage of Component AsynchroSerial.
Robin
6 回复数
2,244 次查看
Robin_Shen
Hi  kirantujare,
The KSDK2.0 doesn't support CodeWarrior10.6.4. CodeWarrior IDE Support to Change for Kinetis Devices. Read More
If you still want use CodeWarrior10.x, please refer the Typical Usage of processor expert.
Robin
2,244 次查看
kirantujare
Thank you Robin! :smileyhappy:
2,245 次查看
Robin_Shen
Hi Kiran,
Robin
2,244 次查看
kirantujare
Hi Robin,
Thank you.
Are there any examples in KSDK for AsynchroSerial?
2,244 次查看
Robin_Shen
Hi  kirantujare,
There are many examples in KSDK2.0 for asynchronous serial communication(UART). These examples are not based on Processor Expert.
You can download it from Kinetis SDK Builder (REV 2 & 1.3).
Robin
2,244 次查看
kirantujare
Hi Robin,
Thank you for the reply.
Are there any examples for CodeWarrior 10.6.4 for twr-k60d100m?
