Programmer recommended for kinetis k64
7,169 次查看
kcg
Hello
I would like to programer through JTAG MCU of kinetis k64, specifically a MK64FN1M0M12. I have been looking programmers of j-link or PE-Micro (USB Multilink Universal,J-link BASE...).
What is programmer the best of MCU kinetis k64?
thanks
5,116 次查看
antonioconcio
Hi Kevin,
The kinetis K series such as K64 supports both JTAG and SWD debug interfaces.
Having said that, both P&E Multilinks and Segger J-Link working great, as well as I-jet if you are using IAR; I'd say to go on with what you have already, if any.
Personally I am fine with J-Link but as mentioned also Universal Multilink is really OK.
I don't know what IDE you are using, in case it is KDS let me add that KDS supports obviously P&E Multilinks (including P&E OpenSDAv1), Segger J-Link (OpenSDAv1 and OpenSDAv2) and OpenOCD with CMSIS-DAP (both OpenSDAv1 and OpenSDAv2).
You can see HERE how to setup debug configurations with recommended settings.
Hope that helps,
Antonio
8 回复数
5,117 次查看
antonioconcio
Hi Kevin,
Hope that helps,
Antonio
5,116 次查看
kcg
Hello Antonio
Sorry to bother you again. Is there any option of low cost programmer with free software? not be necessary I could debug.
thanks
5,116 次查看
antonioconcio
Hello Kelvin,
Please have a look at the following hyperlinks:
Freedom Board with Segger OpenSDA Debug Firmware and KDS settings HERE.
Hope that helps,
Antonio
5,116 次查看
kcg
Hi Antonio
Thanks for your help. Do you know any software free for to program my own hardware through JTAG?
thans Antonio
5,116 次查看
antonioconcio
Sure Kevin,
KDS is what you are looking for.
Please refer HERE for more details.
Antonio
5,116 次查看
kcg
hello Antonio
I've found this device USBDM Emulator BDM Kinetis ARM Support K60 HCS12 HC08 DSP Coldfire | eBay.
I have seen that this device is compatible with MCU K64 but, do I need special hardware in my device to work with this programer to jtag?
thanks
5,116 次查看
kcg
Hi Antonio
Sorry I have not explained well. I'm looking a software that it's only for programmer, because KDS is heavy.
thanks Antonio
5,116 次查看
kcg
Thank you Antonio
your comments have been a great help
