PWMA/eFlexPWM Vs FlexTimer Module in KV4x
2,606 次查看
Vishesh45
In KV4x Reference Manual there are two options to generate PWM
Chapter 37 : Pulse Width Modulator A (PWMA/eFlexPWM)
Chapter 39 : FlexTimer Module (FTM)
what is the difference between these two..??
with both i can successfully  able to generate complimentary pwm signals with deadtime insertion for my full bridge power supply application.
I aslo need to read CADC.
found the document for " FlexTimer and ADC Synchronization for Field Oriented Control on Kinetis ".
is it possible to use ADC in sync with PWM(Chapter 37 : Pulse Width Modulator A (PWMA/eFlexPWM)) .....same as FlexTimer..?
2,515 次查看
_Leo_
I see that you have another case with the same question, I will follow up on this last one that I mention.
2,516 次查看
_Leo_
