Not satisfied with noise on K22FN
2,086 次查看
michaelheidinge
Dear Kinetis-Team,
i have a complain about the Kinetis MCUs, K22FN512.
I did all the art for a good adc result:
1. Voltages are highly stable and noise free
2. ADC inputs are driven by ADC-Driving OpAmps
3. Reference voltage is stable.
4. Solid GND Plane
However, I get noise on my result:
Its 12 binary digits noise at 12 Bit conversion. Thats too much for me, as I want to use the adc in a control loop.
Its approx 0,2%-0,3% noise in the measurement range but this is too much for a good adc, like the datasheet promises.
What can I do better to improve my performance? I want to switch to Kinetis KV44. Will there be better results?
I'm pretty sure you won't do a new revision, but please make more sure next time, you get a good and stable adc result.
Other people also complained with similar results.
https://community.nxp.com/thread/322988
1,852 次查看
michaelheidinge
thanks Ma Hui for your support. I checked that I followed all the recommended steps.
What I tried and did not help:
Current state: 0.15% noise
Practically, I have the same problem as you describe in the 19 counts off example.
-Replaced switching regulator with lab power supply. Same issue.
-Vss&Vref are already highly bypassed.
-No chance to place ferrite beads in the design. However, as no more switching device is left, nor any noise can be seen with 12 bit oscilloscope, i guess this will not make a difference.
-played with sample time: No difference. ADC Channels are actively driven by opamp, so i guess this won't be an issue anyhow.
-reduce the clk divder highly. Same issue.
What helped (if you have same problem):
Changed clk source from Bus Clk to Oscillator Clock: OSCERCLK
So I recommend using OSCERCLK with 8MHz.
Now i have 0.07% noise, which meets the Freescale minimum spec of 10.4 effective bits.
How to calulate: 1/2^ENOB=0,074%
What I guess (it's just a guess, based on the made experience): The Busclock is not stable enough, has some gitter? I use standard 120MHz option for KN512. When I change the frequency from 10MHz to 5MHz same issue.
In case everything else fails:
Oversampleing and averaging.
Generally I would like to have a more stable adc.
4 回复数
1,852 次查看
michaelheidinge
Update: The KE1xF seems to have an decent ADC. Guess, I will use that part.
1,852 次查看
Hui_Ma
There with some suggestions about how to get better performance of Kinetis SAR ADC:
[ADC Calibration]
[Hardware Configuration]
[ADC Configuration]
There also with an application note AN4373 about SAR ADC cookbook, please check here for the detailed info.
Wish it helps.
Ma Hui
1,853 次查看
michaelheidinge
1,852 次查看
michaelheidinge
Just checked with the datasheets: The ADC of the Kinetis just seems so bad, as i measured.
If you look at STM parts, eg. STM32F334, they have a 10dB better SNR ADC build in. I strongly recommend to improve the ADC on the Kinetis devices.
The KV4x 4MSPS ADC gets even worse: It has 9.1 effective bits. Oversampling by a factor of 4 increases the effective bits by 1. This means that that ADC is useless in the KV4x. I need a better ADC on the KVx series!
The KV5 ADC is better, but I cannot afford double the price...
