MY FRDM-K64F doesn't work
1,444 次查看
cyx
it is the first time i use this board. After being connected with computer by USB, the RGB LED keeps flickering and the teraterm can't show any character string even after modify the configration.
And after build a project in KDS, I can't debug. It always shows an error as follow:
An internal error occurred during: "Launching LED_Debug_OpenOCD".
ilg.gnuarmeclipse.debug.gdbjtag.dsf.GnuArmServicesFactory.<init>(Ljava/lang/String;Ljava/lang/String;)V
could someone help me? I'm new to this development board
1,334 次查看
ivadorazinova
Hi yx chen,
thank you for your feedback.
Please, see this post​ if you don´t have issue with the GNU ARM Eclipse plugin.
For this case is needed to replace original files. It is known issue, for this moment it is a workaround.
For your first steps I can recommend you:
Kinetis Design Studio Videos, Part 1: Installation of KDS and Kinetis SDK
Kinetis Design Studio Videos, Part 2: Installation of OpenSDA Firmware on Freedom Board
Kinetis Design Studio Videos, Part 3: Debugging with Kinetis Design Studio
Kinetis Design Studio Videos, Part 4: Using Processor Expert in KDS
Please let me know, if this helps you.
Iva
