MKL25Z128 Internal USB 3.3V regulator limitations
1,235 次查看
MAPC
Senior Contributor I
Can I use the MKL25Z1128 USB 3.3V regulator to power the MCU, if I don't surpass Iout = 120mA?
Marco Coelho
1,135 次查看
Hui_Ma
Hi Marco,
Yes, you can use KL25 USB regulator 3.3V output to power the KL25 chip, please refer the application below:
Wish it helps.
Ma Hui
1,136 次查看
Hui_Ma
Hi Marco,
Wish it helps.
Ma Hui
