MKL16 UART can not receive
2,442件の閲覧回数
jiannianli
Hi ,
I had some questions about Uart receive when i use uart base on MKL16 .
I had create project by PE(Driver Suite v10.4) ,now uart can send data ,   but can not receive data . Belows is my codes:
Now it can send data ,but can not receive data , I really do not know whats wrong ,please help me,thanks
タグ(1)
2,298件の閲覧回数
nxf56274
Sorry about that we no longer support the PE. You can download the sdk in the https://mcuxpresso.nxp.com/en/select . You can refer it and find the difference between the sdk and your code.
TIC
- We are following threads for 7 days after the last post, later replies are ignored
2,299件の閲覧回数
nxf56274
TIC
2,298件の閲覧回数
jiannianli
OK , thank you very much , I will try .
