MKL16 UART can not receive
1,615 次查看
jiannianli
Hi ,
I had some questions about Uart receive when i use uart base on MKL16 .
I had create project by PE(Driver Suite v10.4) ,now uart can send data ,   but can not receive data . Belows is my codes:
Now it can send data ,but can not receive data , I really do not know whats wrong ,please help me,thanks
标记 (1)
1,471 次查看
nxf56274
Sorry about that we no longer support the PE. You can download the sdk in the https://mcuxpresso.nxp.com/en/select . You can refer it and find the difference between the sdk and your code.
TIC
- We are following threads for 7 days after the last post, later replies are ignored
1,472 次查看
nxf56274
TIC
1,471 次查看
jiannianli
OK , thank you very much , I will try .
