LK05Z IAR
LK05Z IAR
8,191 次查看
admin
Specialist II
I have an KL05Z board. I have open SDA CDC port working and I can drag and drop programs to the board but I am totally unable to make my KL05Z work with IAR free evaluation, code length limited version. I get the following error when atempting to download the code to the board: Fatal error: Failed to initialize PEMicro interface DLL.   Session aborted!  I have tried almost everything...
Please, help!
Manuel
7,725 次查看
admin
Specialist II
Hector,
I now got it working, at last! the "OpenSDA Debug Driver" was missing
under "Jungo"
I have found the installation of the drivers very tricky... :smileysad: Whish they
improve it!
Thanks for your kind help. Regards,
Manuel
2013/12/2 Hector Sanchez <[email protected]>
<https://community.freescale.com/> Re: LK05Z IAR
reply from Hector Sanchez<https://community.freescale.com/people/hectorsanchez?et=watches.email.thread>in *Kinetis
Hardware Support* - View the full discussion<https://community.freescale.com/message/366181?et=watches.email.thread#366181>
4 回复数
7,725 次查看
hectorsanchez
Hi Manuel,
Probably it's because you are missing the drivers from P&E Microcomputer Systems, i recommend you to download and install them here: http://www.pemicro.com./ Hope this helps, keep me informed.
Hector Sanchez
7,722 次查看
admin
Specialist II
Thanks Hector,
I did download and install the drivers several times but probably, for some
uknown reason, they refuse to install corectly. I attach a screenshot of
my device manager after the installation. Can you please tell me what is
wrong or missing? I am on Windows7 64bits.
Thanks for your help,
Manuel
<https://community.freescale.com/> LK05Z IAR
Hardware Support* - View the full discussion<https://community.freescale.com/message/366172?et=watches.email.thread#366172>
7,721 次查看
hectorsanchez
Hi Manuel,
Maybe your board is not in OpenSDA Debug mode, here is a quick tutorial on how to enter the Bootloader mode to configure your board as a debugging interface.
I will provide you with an example on how to configure your board provided by Erich Styger's blog: OpenSDA on the Freedom KL25Z Board | MCU on Eclipse
I will leave the Quick Start Guide if you need it too.
Keep me informed,
Hector Sanchez
7,726 次查看
admin
Specialist II
Hector,
under "Jungo"
improve it!
Manuel
